Stability of reactingTwoPhaseEulerFoam with wall boiling simulations |
Achref Rabhi
Rep Power: 7 ![]() |
Dear all,
I am trying to model the boiling flow, in a pipe (2D, wedge BC), using reactingTwoPhaseEulerFoam. The cases with a rectangular geometry work good and give fair results. When I change the geometry to a pipe (2D wedge or 3D pipe), the simulation diverges and gives very high temperature values. I used different mesh configurations, different applied heat fluxes, disable the energy equation for the gas phase, fvOption to limit the temperature but without any result. It always diverges. I even tried to do the same simulation set up for the wall boiling tutorial case but with a pipe geometry but it stills diverge. Does any one have experience with this solver to simulate wall boiling cases? This will be a real help for me. ![]() ![]() Thank you in advance Achref |
Stanley John
Rep Power: 8 ![]() |
HI
I am simulating a similar problem. What kind of boundary conditions did you put for p and p_rgh for inlet and outlet? |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Effect of Wall Roughness in Low-Turbulence simulations? | gabitinho | OpenFOAM Running, Solving & CFD | 0 | December 17, 2015 07:42 |
[mesh manipulation] mergeMeshes problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 3 | July 29, 2015 04:15 |
RAS simulations of flow around wall mounted cube | nore5 | OpenFOAM Running, Solving & CFD | 0 | February 13, 2013 09:55 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
