multiPhaseEulerFoam - velocity decay in channel / impossible to add a momentum source
Old   June 11, 2019, 10:11
Default multiPhaseEulerFoam - velocity decay in channel / impossible to add a momentum source
lucb-cfd is on a distinguished road
Hi everyone,
I am trying to model an air/water flow in a channel (the initial field is set with setFields with a chosen water level and cyclic conditions in the flow direction are set with a fixed velocity for each phase), see the joined picture.
I realised that the flow velocity would decrease with time and the only solution I found is to add a momentum source with fvOptions, using a mean velocity field, which I did such as (for the air phase):
momentumSource
type meanVelocityForce;
active yes;
patchMeanVelocityForceCoeffs
selectionMode all;
fields (U.air);
Ubar (3.66 0 0);
relaxation 1.0;
The problem is that I get a warning after the second time step "Source momentumSource defined for field U.air but never used".
Then I realised that the source term wasn't present in /opt/openfoam6/applications/solvers/multiphase/multiphaseEulerFoam/UEqn.H so I added it like it is implemented in any other solvers:
UEqns.set
phasei,
new fvVectorMatrix
fvm::ddt(alpha, U)
+ fvOptions(U)
However I get an error when compiling "error: 'fvOptions' was not declared in this scope".
I tried to include fvOptions (#include "fvOptions.H") at the beginning of UEqn.H with not results.
Any help will be much appreciated to solve this last error, or any suggestions to avoid this velocity decay along the channel.
Cheers,
Luc
PS : I am aware that a former post concerning velocity decay already exists but it does not solve my issue as my periodic conditions should maintain the velocity field constant. (Openfoam - setFields - Creates velocity that does not move and decays in place)
lucb-cfd is offline   Reply With Quote
fvoptions, momentum source, multiphaseeulerfoam, velocity decay
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
Mass source, Momentum source theory. diffo FLUENT 4 August 21, 2009 11:26
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
