anyone like to explain previous time-step mesh compression flux? |
June 10, 2019, 12:09 |
In an interFoam.C file, under dynamic mesh code, after if (mesh.changing())
there is an cautionary comment saying: 'do not apply previous time-step mesh compression flux!' So, why is that? In what applications I need to apply previous time-step mesh compression flux? is it related to compressible fluid, and in-compressible fluid CFD simulations? or is it just a C++/coding related cautionary comment? |
October 4, 2023, 12:26 |
Michael Sukham
Rep Power: 6 |
Have you worked it out? Because I had the same problem regarding the compression flux. In foamExtend, it is not there. It is a bit hard to figure out without having a test case .
compression flux, interfoam, main c++ file, mesh, time-step |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 03:05 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 23:40 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
