overPimpleDyMFoam runs computation on moving mesh only |
June 9, 2019, 10:12 |
i have been trying to make a square move as a transient computation, but it seems that the computation is done only in the moving mesh, there is no continuity of the solution around it. my computation is just a modification of the simple rotor tutorial, so it should work. Does anyone have an idea of the source of this problem? Thank you in advance! (the mesh quality was necessary to debug it fast, but the same problem appears with a 200cell wide square) |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 11:58 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
