pyFoamPlotRunner
Old   June 6, 2019, 06:53
Default pyFoamPlotRunner
Owais Shabbir
Owais Shabbir is on a distinguished road
Dear All,
I have a very simple question. I am running my case and I have around 3000 steps to be simulated. I run my case using
pyFoamPlotRunner.py simpleFoam > log.simplefoam
When I am looking at the graphs I notice that epsilon shoots to an extremely high value as shown in the pic. But later it gets better and I would like to read the values been updated on the graph but the y-axis is extended making it impossible to read the instant values. Is there a way to make the 'Bounded Variables' graph to only show last few steps value instead of showing it from 0.
Secondly does it matter if the epsilon behaves initially in this behavior because the other variables don't show a similar trend. The Cumulative Continuity also tries to converge at -60 which I can't really judge if it is a good value or not.
Details about my case:
simpleFoam with k-epsilon model
Calculating epsilon = (0.09^0,75)*(k^1,5)/L
Relaxation factors: p=0,2 U=0,7 k=0,4 epsilon=0,6
Owais Shabbir is offline   Reply With Quote
Old   June 11, 2019, 10:30
Default one possible solution
Owais Shabbir
For people stumbling upon this question, I found an alternative way for this.
In the controlDict file, for the startFrom option chose the entry latestTime. Simply restart the simulation and the graphs will be updated with the new values.
Remarks: Some errors might show up in the restarting of the simulation and that is because the final time folder you stopped at isn't completed. So just delete that folder and it will work fine.
If anyone else want to give their insights on this, I'd also appreciate it.
Old   February 21, 2023, 05:31
GaryCooper is on a distinguished road
I came up with an alternate solution for anybody who may come into this dilemma in the future.
When prompted in the controlDict file, choose the item under "latestTime" for the startFrom option. Merely resume the experiment, and the new numbers will be reflected in the graphs when they have been updated.
Remarks: When you begin the simulation, you may see that certain errors have occurred; this is due to the fact that the folder containing the most recent saved time is incomplete. You may thus remove that folder, and everything will continue to function normally.
flappy bird
I'd be grateful to hear from anybody else who has thoughts on this matter, if they want to share them.
GaryCooper is offline   Reply With Quote
continuity residual, gnuplot, pyfoamplotrunner, residuals
How to see pyFoamPlotRunner again? pela145 OpenFOAM Running, Solving & CFD 0 February 13, 2016 08:26
pyFoamPLotRunner & pimpleDyMFoam: plotting reidual by iterations, not timeStep student666 OpenFOAM Running, Solving & CFD 0 January 20, 2015 13:41
[PyFoam] why pyFoamPlotRunner doesn't plot continuity residuals? immortality OpenFOAM Community Contributions 10 May 5, 2013 07:13
[PyFoam] pyFoamPlotRunner on network PeterX30 OpenFOAM Community Contributions 2 December 12, 2012 16:28
[PyFoam] How to return initial scale in gnuplot whire running pyFoamPlotRunner.. j-avdeev OpenFOAM Community Contributions 1 December 27, 2011 08:45
