printStack problem in running my rhoCentralFoam
Old   June 3, 2019, 23:53
Default printStack problem in running my rhoCentralFoam
Aaron
derBodat is on a distinguished road
Hi there,
I'm new to this forum and been using OpenFOAM for 4 months now.
I'm currently running a rhoCentralFoam solver for a CD nozzle, for this simulation I've been varying the usage of both fine and coarse meshes while also tweaking a bit their controlDict(especially with its deltaT, endTime, writeInterval). However I've stumbled upon an error which seems to be common with all of my simulations, that is this line:
[1] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[1] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:?
[1] #4 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:?
[1] #5 ? in "/usr/bin/rhoCentralFoam"
[1] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #7 ? in "/usr/bin/rhoCentralFoam"
[aaron-SVS13112EGB:10027] *** Process received signal ***
[aaron-SVS13112EGB:10027] Signal: Floating point exception (8)
[aaron-SVS13112EGB:10027] Signal code: (-6)
[aaron-SVS13112EGB:10027] Failing at address: 0x3e80000272b
[aaron-SVS13112EGB:10027] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x41100)[0x7f5d346d2100]
[aaron-SVS13112EGB:10027] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f5d346d2077]
[aaron-SVS13112EGB:10027] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x41100)[0x7f5d346d2100]
[aaron-SVS13112EGB:10027] [ 3] /usr/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThe rmoINS_9psiThermoENS_11pureMixtureINS_19sutherland TransportINS_7species6thermoINS_12hConstThermoINS_ 10perfectGasINS_6specieEEEEENS_22sensibleInternalE nergyEEEEEEEE9calculateEv+0x193)[0x7f5d36406573]
[aaron-SVS13112EGB:10027] [ 4] /usr/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThe rmoINS_9psiThermoENS_11pureMixtureINS_19sutherland TransportINS_7species6thermoINS_12hConstThermoINS_ 10perfectGasINS_6specieEEEEENS_22sensibleInternalE nergyEEEEEEEE7correctEv+0x2a)[0x7f5d3642531a]
[aaron-SVS13112EGB:10027] [ 5] rhoCentralFoam(+0x3633f)[0x55ae2a06e33f]
[aaron-SVS13112EGB:10027] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xeb)[0x7f5d346b509b]
[aaron-SVS13112EGB:10027] [ 7] rhoCentralFoam(+0x3886a)[0x55ae2a07086a]
[aaron-SVS13112EGB:10027] *** End of error message ***
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 1 with PID 0 on node aaron-SVS13112EGB exited on signal 8 (Floating point exception).
Now I've tried several solutions online, I've checked my mesh via checkMesh, which had a problem at the beginning, fixed it, mesh is OK but still haven't solved this error yet. I tried running on OpenFOAM debug by editing its bashrc file, but seems to be no different than before(I'm not sure if that's the way to run debug version, let me know if you know a better way), my boundary conditionsare on the proper units (Pa, m/s, and so on..)
Please help.. I'm a bachelor student writing my thesis and in one week is my deadline.
Regards,
Aaron.
derBodat is offline   Reply With Quote
#cdnozzle, #printstack, #rhocentralfoam
ANSYS Licensing Problem, Processes Running but Showing as Not Running penguinman ANSYS 3 September 27, 2016 14:30
[Other] Problem running after decomposition paul.m.edwards OpenFOAM Meshing & Mesh Conversion 0 January 14, 2015 13:55
Problem while running in Highperformance computing environment Phanipavan STAR-CD 1 September 11, 2013 07:42
problem with running in parallel dhruv OpenFOAM 3 November 25, 2011 06:06
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
