How to use Paraview to view results when finished running reactingFoam?
Old   June 3, 2019, 11:39
Default How to use Paraview to view results when finished running reactingFoam?
S Li
FlameKan is on a distinguished road
Hi guys,
I am running the Sandia FlameD with reactingFoam. After running for 3000 time steps, I'd like to view the results in ParaView. But there is no such a .foam file to be loaded to Paraview, like the one "cavity.foam" of the tutorial case.
Can anyone help me on this? Thank you very much.
FlameKan is offline   Reply With Quote
Old   June 3, 2019, 12:06
BlnPhoenix is on a distinguished road
Type in terminal (in your case directory):
"touch myname.foam" and myname.foam file will appear in your case directory.
BlnPhoenix is offline   Reply With Quote
Old   June 4, 2019, 03:58
S Li
It works ! Thanks!
But when I tried using paraFoam, it did not work. There was an error message showing: environment value not set. Can you help on this?
Last edited by FlameKan; June 4, 2019 at 04:02. Reason: forgot to quote original message
Old   June 4, 2019, 03:59
S Li
It works ! Thanks!
Postprocessing STAR-CCM+ results in ParaView philipp_buehl STAR-CCM+ 2 February 28, 2019 10:54
[General] Running paraview parallel on windows 7 Naruto ParaView 3 April 22, 2017 08:12
Import STAR-CD results -> Paraview BenBoo Siemens 7 March 29, 2012 06:02
how to view the complete results shokry FLOW-3D 5 February 3, 2009 14:56
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
