Change in thermophysicalProperties leads to error
Old   May 31, 2019, 09:05
Default Change in thermophysicalProperties leads to error
Korbinian Faust
Kobi_Faust is on a distinguished road
Hi all,
I'm having a multi region model, solving it with the solver chtMultiRegionFoam.
Everything runs well so far. Now I did some changes on the thermophysicalProperties of the fluid region. With this I'm getting a "Floating point exception" error. Any ideas where this comes from? Or what I am doing wrong?
Attached the old and new thermophysicalProperties file, and the terminal log.
Old thermophysicalProperties:
|  \\    /   O peration     | Version:  dev                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      thermophysicalProperties;
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectFluid;
    specie          specie;
    energy          sensibleEnthalpy;
mixture
    specie
        molWeight       18; //g per mol
		nMoles			1;
    equationOfState
        R           3000;
        rho0        1027;
    thermodynamics
        Cp          4183;
        Hf          0;
    transport
        mu              959e-6;
        Pr              4.56;
New thermophysicalProperties:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
thermoType
    type            heRhoThermo;
    transport       polynomial;
    thermo          hPolynomial;
    equationOfState icoPolynomial;
    specie          specie;
mixture
    specie
		nMoles			1;
    equationOfState
        rhoCoeffs<8> ( 765.33 1.8142 -0.0035 0 0 0 0 0);
    thermodynamics
               Hf          0;
		Sf			0;
		CpCoeffs<8> ( 28070 -281.7 1.25 -0.00248 0.000001857 0 0 0);
    transport
        	muCoeffs<8> (0.0967 -0.0008207 0.000002344 -0.000000002244 0 0 0 0);
		kappaCoeffs<8> (-0.5752 0.006397 -0.000008151 0 0 0 0 0);
log-file:
|  \\    /   O peration     | Version:  v1812                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : v1812 OPENFOAM=1812
Arch   : "LSB;label=32;scalar=64"
Exec   : mychtMultiRegionFoam
Date   : May 31 2019
Time   : 13:51:07
Host   : hmc01.cluster.frm2.tum.de
PID    : 38852
I/O    : uncollated
Case   : /localhome/kfaust/Coupling_V6.5/OF_V6.5
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create fluid mesh for region Wasser for time = 0
Create solid mesh for region Meat_15 for time = 0
Create solid mesh for region Meat_30 for time = 0
Create solid mesh for region Plattenrahmen for time = 0
Create solid mesh for region Cladding_aussen for time = 0
Create solid mesh for region Cladding_innen for time = 0
Create solid mesh for region Kamm_oben for time = 0
Create solid mesh for region Kamm_unten for time = 0
Create solid mesh for region Rand_aussen for time = 0
Create solid mesh for region Rand_innen for time = 0
*** Reading fluid mesh thermophysical properties for region Wasser
    Adding to thermoFluid
Selecting thermodynamics package
    type            heRhoThermo;
    thermo          hPolynomial;
    specie          specie;
AMI: Creating addressing and weights between 657432 source faces and 656858 target faces
AMI: Patch source sum(weights) min:0.98604664 max:1.000062 average:0.99998044
AMI: Patch target sum(weights) min:0.98186748 max:1.0001693 average:0.99998884
    Adding to rhoFluid
    Adding to UFluid
    Adding to phiFluid
    Adding to hRefFluid
    Adding to ghFluid
    Adding to ghfFluid
    Adding to turbulenceFluid
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
    Adding to reactionFluid
Combustion model not active: combustionProperties not found
Selecting combustion model none
    Adding to radiationFluid
Selecting radiationModel none
    Adding to KFluid
    Adding to dpdtFluid
    Adding to fieldsFluid
    Adding to QdotFluid
    Adding MRF
No MRF models present
    Adding fvOptions
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in /lib/x86_64-linux-gnu/libc.so.6
#3  logf32x in /lib/x86_64-linux-gnu/libm.so.6
#4  Foam::compressible::alphatJayatillekeWallFunctionFvPatchScalarField::updateCoeffs() at ??:?
#5  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate() at ??:?
#6  Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > >::correctNut() at ??:?
#7  Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correctNut() at ??:?
#8  ? at ??:?
#9  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#10  ? at ??:?
Floating point exception (core dumped)
Tank you for your help.
Kobi
Kobi_Faust is offline   Reply With Quote
Old   May 31, 2019, 09:24
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Hello Kobi,
I never used polynomial function in chtMultiregionFOAM. But it seems like Prandtl number is missing in your new thermophysicalProperties. I am not really sure if it is not required in case of polynomial functions of physical properties.
Regards
mwaqas is offline   Reply With Quote
Old   May 31, 2019, 12:30
Korbinian Faust
Hello Muhammad,
thanks for your answer. Thats true, that the Prandtl number is missing. But it didn't change when adding it.
If only one entry would be missing, the failure should be something like "keyword missing".
So it must be some different mistake.
I would appreciate further ideas.
Regards,
Kobi
Old   June 1, 2019, 09:04
Joachim Herb
jherb is on a distinguished road
The crash happens in
You could try to find the exact location and the values of the variables/fields?
Also have you tried to decrease relaxation factors and/or time step size?
jherb is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
