Open channel with periodic boundary conditions not converging |
May 31, 2019, 06:02 |
Paul S
Rep Power: 8 |
I'm trying to simulate an open channel with periodic boundary conditions. I've based it of channel 395 only mine is an open channel, uses a RANS turbulence model and uses the simpleFoam solver. My results don't seem to be reaching solution convergence, any idea why that might be? case files are in the zipped folder. |
June 1, 2019, 06:49 |
Paul S
Rep Power: 8 |
It looks like there is something wrong with my pressure value. I thought the fvoptions would sort this but its not the case
June 7, 2019, 06:47 |
Paul S
Rep Power: 8 |
I think I need to specify a pressure drop across Inlet and Outlet regions can this be done wit the boundary conditions I'm using?
May 28, 2020, 11:35 |
#4 | |
Carlos Andrés Barros
Hi Stanley91, did you manage to find a solution for your problem ?, I think I'm experiencing the same issue in an open channel flow simulation. Thanks in advance. |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
Open Channel Boundary Conditions via journal | Matteo | FLUENT | 0 | January 21, 2008 12:05 |
