GGI zone-to-zone interpolator giving very high values |
#1 | ||
Aashay Tinaikar
Rep Power: 7 ![]() |
Hello fellow cfd enthusiasts,
I am trying to simulate a case using fsiFoam solver. I have meshed solid and fluid domains separately and their interface patches do not have coincident faces. When I run fsiFoam, I get the following values for GGI zone-zone interpolator. Quote:
As you can see, the slave point distances are astronomical. Lateron, it fails in the 1st iteration of solid solver. I am not sure what the problem is. Quote:
My fluid mesh is good and I have some wrongly oriented faces in the solid mesh. (8 out of 10s) Could this be the cause of this issue? If yes, could anyone also guide me as to how I can reorient those faces? |
fsifoam, ggi |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
Create a GeometricField of a given type on given patch? | philippose | OpenFOAM Programming & Development | 4 | August 12, 2013 12:41 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
Segmentation Fault in fluent3DMeshToFoam | cwang5 | OpenFOAM Bugs | 23 | April 13, 2011 15:37 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
