InterFOAM in a channel: boundary In/Outlet
Old   May 28, 2019, 12:26
Default InterFOAM in a channel: boundary In/Outlet
VentinS is on a distinguished road
Dear Foamers!
I started with a simulation of a simple 3D channel with interFoam, I never worked with this solver and I'm pretty confused.
The geometry is something like this:
_____________________________
Inlet(water) ->| air | Outlet
My idea was:
outlet p: fixedValue; uniform 0; it worked well with simpleFoam,
inlet U: flowRateInletVelocity; with volumetricFlowRate (this works fine)
walls with noSlip (The picture is misleading, it is from my first try where the walls U were: fixedValue; value uniform (0 0 0); )
and the alphaWater seems to rise, which is nice
My questions are:
how do I define this free stream condition, for the pressure?
and why is the velocity zero behind the flow?
Thanks in advance!
VentinS is offline   Reply With Quote
Old   May 28, 2019, 14:18
OK, I think I got it, so maybe for someone with a similar problem:
The pressure on the outlet works fine (at least for me) with:
type fixedValue;
value uniform 0;
The velocity is NOT zero!
With hover cells on, it shows the correct velocity.
And note to self, the pressure is already in Pa
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 22:16
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
