Keyword direction is undefined in dictionary
Old   May 26, 2019, 04:32
Smile Keyword direction is undefined in dictionary
Outside US and Canada
sidvud98 is on a distinguished road
My Problem
When I use the command simpleFoam, I get the following error
No MRF models present
No finite volume options present
Starting time loop
streamLine streamlines:
--> FOAM FATAL IO ERROR:
keyword direction is undefined in dictionary "/home/sid/CFD/lily/postrun/system/streamlines"
file: /home/sid/CFD/lily/postrun/system/streamlines from line 13 to line 20.
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 566.
What I tried
I tried to create
direction (0 0 1);
in streamlines.c to only find later it wasn't helping.
for reference,
I'm simulating a cylinder.stl file as shown in https://youtu.be/oc4V79F78AQ?t=734
And I get the error at 12:16
sidvud98 is offline   Reply With Quote
Old   October 24, 2019, 10:52
Smile Edit streamlines.cfg
TN
tommanuel is on a distinguished road
streamlines.cfg is located in:
/opt/openfoam6/etc/caseDicts/postProcessing/visualization/
edit streamlines.cfg to look like this:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
type streamLine;
libs ("libfieldFunctionObjects.so");
executeControl writeTime;
writeControl writeTime;
setFormat vtk;
direction forward;
lifeTime 10000;
nSubCycle 5;
cloudName particleTracks;
seedSampleSet
type lineUniform;
axis x;
start $start;
end $end;
nPoints $nLines;
Why does this work? Not sure. I happened to have openfoam installed on multiple computers and this tutorial worked on one but not the other. When I traced the errors back, I noted streamlines.cfg was missing lines for the computer that didn't work. Perhaps these were put in place when I ran other simulation tutorials in the user manual.
tommanuel is offline   Reply With Quote
fatal error, fatal io error, openfoam, simplefoam, simplefoam not converged
keyword PISO is undefined in dictionary, Please help. TommiPLaiho OpenFOAM Pre-Processing 2 May 26, 2019 04:50
problem with turbulence models after compilation? lfgmarc OpenFOAM Programming & Development 19 November 20, 2013 01:50
keyword potentialFlow is undefined in dictionary, please help. TommiPLaiho OpenFOAM Pre-Processing 2 October 21, 2013 18:12
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
