May 23, 2019, 11:04 |
VoF losing Fluid transient
Dear All,
I am shacking a small tube about 7mm Diameter und 12 mm high with a starting Fluid of 60µl of Water with 1100rpm. I am using the multiphaseInterFoam with surface tension and contact angle water to air. The Problem is that after 1.1s time the fluid is just something like 50% left. I tried diffenret CFL-Numbers, smaller timestep, more cells, higher precision (12) and some changes in fvSolver and fvSchemes. I am a bit lost and hope for new input. Thanks in advance Torsten |
losing fluid, multiphaseinterfoam, vof multiphase |
VOF split Lagrangian Method for one Fluid!!!! | D.Abedi | FLOW-3D | 0 | January 2, 2019 12:43 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | FLUENT | 0 | July 22, 2016 14:39 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
