bubbleColumn change Inlet position to top does't work with compressible flow
Old   May 23, 2019, 07:58
Talking bubbleColumn change Inlet position to top does't work with compressible flow
Siqi Ma
masimasiqi is on a distinguished road
I am running twoPhaseEulerFoam in the case of bubbleColumn and I changed the inlet to the top and outlet to the bottom which can be approximated to a standing pipe with air injected from top
- in blockMesh I exchanged the position of the patch inlet and patch outlet from the sample case, so the air bubbles are injected from the top and the mixture fluid flows out from bottom.
code from file blockMeshDict
patches
    patch inlet
        (3 7 6 2)
    patch outlet
        (1 5 4 0)
- in setFields I set the whole fluid domain with water(alpha.air=0)
code from file alpha.air
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
- because the inlet is changed to the top so the velocity of injected air should change direction
code from U.air
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 -0.1 0);
- in thermophysicalProperties, I change the equationOfState from perfectGas/perfectFluid to rhoConst in thermophysicalProperties to obtain incompressible flow.
code from thermophysicalProperties.air
thermoType
    type             heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState rhoConst;
    specie           specie;
    energy          sensibleInternalEnergy;
mixture
    specie
        molWeight   28.9;
    equationOfState
        R           3000;
        rho         1164;
    thermodynamics
        Cp          1007;
        Hf          0;
    transport
        mu          1.84e-05;
        Pr          0.7;
the result seems to be right, air injects into water
alpha.air
p_rgh
but if i deal with the original thermophysicalProperties (equationOfState : perfectGas) which means compressible flow. The outcome is quite unrealistic... The upper part is filled with complete air and pushing down the fluid, there is no "injection" into the water
alpha.air
p_rgh
I think the unrealistic behavior in compressible flow (perfectGas/perfectFluid) is because of the density change affects the pressure.
the solver twoPhaseEulerFoam use p_rgh rather than p to solve the result.
p \_ rgh = p - \rho g \cdot x
\nabla p \_ rgh = \nabla - \rho g - g \cdot x \nabla \rho
(btw all the other boundary conditions remain exactly the same as original case)
code of file p_rgh
dimensions          [1 -1 -2 0 0 0 0];
internalField       uniform 1e5;
boundaryField
    inlet
        type            fixedFluxPressure;
        value           $internalField;
    outlet
        type            prghPressure;
        p               uniform 110000;
    walls
code of file p
boundaryField
    inlet
        type               calculated;
    outlet
        type               calculated;
    walls
        type               calculated;
I also have tried to change several boundary conditions of p_rgh, p, U.air and U.water, nothing works out.
Does anybody has any idea or relative thought about how could I deal with the compressible case?
- about boundary condition especially of p_rgh?
- about part of the solver code about pressure to dig into?
thanks a lot, even some hints will be really helpful.
masimasiqi is offline   Reply With Quote
bubble column, compressible, p_rgh, thermophysicalproperties, twophaseeulerfoam
Solution does not change in transient 3D compressible flow ticofiz FLUENT 2 October 4, 2022 13:36
How can it possible to change by itself in volumetric flow rate of velocity inlet BC oozcan FLUENT 10 November 25, 2016 05:54
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 02:31
Supersonic Inlet for a Compressible Flow in a Nozzle Daco FLUENT 8 November 8, 2012 04:34
