compressibleInterFoam // Re-initialisation error
Old   May 22, 2019, 12:36
Default compressibleInterFoam // Re-initialisation error
Marc Batlle
Marc Batlle is on a distinguished road
Dear Foamers,
I am working nowadays with the multiphase solver "compressibleInterFoam" in this case propagating waves. I am still in an essay/error stage, but I am having some troubles "casually" and I still couldn't find where do they come from.
I just added the static wave generator boundary condition "EXE_LIBS=lwaveModels" used in interFoam, there is where the "compressibleWaveFoam" name come from. I am using of-v1806.
------------------------ The problem ------------------------
When interrupting a case while it is running and re-initializing, it directly crashes. I attached a test case and it will crash if, for example, we stop it at t=6.1s.
Files:
- Test case: zip file with the test case
- log.compressible
- Error: Terminal output
Marc Batlle is offline   Reply With Quote
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 01:10
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
