Interpolating scalarField values between two non conformal patches
Old   May 22, 2019, 11:36
Default Interpolating scalarField values between two non conformal patches
Anubhav
goku15 is on a distinguished road
I am performing a simulation on an aircraft and needed to simulate the engine using a give fan pressure ratio and polytropic efficiency. I have implemented this using a CodedFixedValue boundary condition between two patches (fanInlet and fanOutlet) as below. This uses the values of the scalar field from one patch and assigns appropriate values to the inlet into my domain (fanOutlet).
My problem is that this requires both the patches to have same number of faces. I know tools like AMIInterpolation can be used to interpolate and assign values to patches with different number of faces. But I have no ídea how to implement this in my condition. I would really appreciate any help.
|    HiSA: High Speed Aerodynamic solver                                      |
|    Copyright (C) 2014-2017 Johan Heyns - CSIR, South Africa                 |
|    Copyright (C) 2014-2017 Oliver Oxtoby - CSIR, South Africa               |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      k;
include         "include/freestreamConditions"
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform $k;
boundaryField
    inlet
            type            turbulentIntensityKineticEnergyInlet;   // inletOutlet;
            intensity       0.001;                                  // = 0.1% intensity
            value           $internalField;
    outlet
               type         zeroGradient;
     atmosphere
            type            zeroGradient; //fixedValue;
   //     uniform         $internalField;
    nacelle
            type            boundaryCorrectedFixedValue;
            value           uniform 0;
     fuselage
            value           uniform 0;
    fanInlet
            type            zeroGradient;
    fanOutlet
    type            codedFixedValue;
    redirectType    kOutletFanBC;
    code
            const dictionary& fvSolution = db().lookupObject<IOdictionary> ("fvSolution");
            scalar turbulentIntensity = fvSolution.subDict("fanCharacteristics").lookupOrDefault<scalar>("turbulentIntesity", 0.1);
            const word& inletPatchName = fvSolution.subDict("fanCharacteristics").lookup("inletPatch");
            const word& outletPatchName = fvSolution.subDict("fanCharacteristics").lookup("outletPatch");
            const fvPatch& p = this->patch();
            label inletPatchID = p.patch().boundaryMesh().findPatchID(inletPatchName);
            label outletPatchID = p.patch().boundaryMesh().findPatchID(outletPatchName);
            const fvPatch& inletPatch = p.boundaryMesh()[inletPatchID];
            const fvPatch& outletPatch = p.boundaryMesh()[outletPatchID];
            const vectorField& uInlet = inletPatch.lookupPatchField<volVectorField, vector> ("U");
            const scalarField& k_FinalOut = outletPatch.lookupPatchField<volScalarField, scalar> ("k");
            // field values:
            scalarField magu = mag(uInlet);
            scalar uMean = gSum(inletPatch.magSf() * magu) / gSum(inletPatch.magSf());
            scalarField k_Outlet = mag(uInlet);
            forAll (k_Outlet , faceI)
                k_Outlet[faceI] = 3 * pow((uMean * turbulentIntensity), 2) / 2 ;
            scalarField& kOutletField = *this;
            forAll (kOutletField, faceI)
                kOutletField[faceI] = k_Outlet[faceI];
                operator == (k_Outlet);
        codeInclude
                    #include "fvCFD.H"
        codeOptions
                      -I$(LIB_SRC)/finiteVolume/lnInclude \
                      -I$(LIB_SRC)/meshTools/lnInclude
        codeLibs
                    -lmeshTools \
                    -lfiniteVolume
    frontAndBack_left
            type            wedge;
    frontAndBack_right
            type            wedge;
goku15 is offline   Reply With Quote
Old   May 24, 2019, 10:39
Anubhav
Is there no one who can help?
Old   May 28, 2019, 11:51
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Check out section 3.6. It might be helpful for you. I didn't try myself. But the example has been given when both patches have different number of faces.
http://openfoamwiki.net/index.php/Contrib/groovyBC
Regards
mwaqas is offline   Reply With Quote
Old   May 31, 2019, 13:17
Michael Alletto
mAlletto will become famous soon enough
Maybe this is useful How to define a non-comformal interface
mAlletto is offline   Reply With Quote
boundary condition, boundary conditions
[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised" preibie OpenFOAM Meshing & Mesh Conversion 28 March 29, 2017 05:56
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 09:00
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 13:40
exact face values RubenG Main CFD Forum 0 June 22, 2009 12:09
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 13:04
