Obtaining negative temperature sonicFoam
Old   May 22, 2019, 07:47
Default Obtaining negative temperature sonicFoam
adrian chelaru
chelucupar is on a distinguished road
Hello!
I am trying to simulate a Naca0012 profile, using the sonicFoam solver.
My trouble is that I am obtaining a negative temperature and the solver crashes. Also, if I plot the residuals, the continuity equation shows negative values. Anyone has any ideas? I saw some posts with similar problems, but no result was found what so ever.
I am also having troubles with setting my boundaries conditions. I am new in openFoam. My trouble is, what kind of boundary conditions should I set if I want to have a farfield like in Fluent?
chelucupar is offline   Reply With Quote
Old   May 24, 2019, 01:53
Default tutorial case?
Will Kernkamp
wkernkamp is on a distinguished road
I usually start from a tutorial case. For sonicFoam look in compressible.
wkernkamp is offline   Reply With Quote
Old   July 17, 2019, 15:58
Lightbulb Try and control cfl number using adjustable time step feature in OF
Dumbledore
hemanthgrylls is on a distinguished road
https://www.cfd-online.com/Forums/op....html#poststop
check this out
Increase in courant number maybe the reason for blowup
A same time step through out the simulation is not suitable
During some iterations the demand for time step is very less due to flow characteristics in the domain and non robustness of the solver.
so try to enable "adjustabletimestep" in controldict which can control time step and controls the steady increase in courant number
add this lines in your controldict code:
HTML Code:
adjustTimeStep  yes;
maxCo               0.7;
maxDeltaT          0.01;
You can also limit the degree of temperature value update after every iteration using relaxation factor for you energy equation.
HTML Code:
relaxationFactors
      fields
          p                           0.3;
          T 			       0.3;
      equations
         U                            0.4;
        "(rho|k|nuTilda|e).*" 0.4;
hemanthgrylls is offline   Reply With Quote
Old   July 17, 2019, 16:04
Dumbledore
https://www.openfoam.com/documentati...conditions.php
http://www.nextfoam.co.kr/lib/downlo...bb43ccfe025b25
Please go through these links and these might help you as a reference when you while you are stuck in defining boundary conditions.
negative temperature, openfoam., sonicfoam
Negative temperature and pressure in sonicFoam :O gallon OpenFOAM Running, Solving & CFD 17 July 19, 2024 20:58
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
Unexpected large decrease in Total temperature across the shock using sonicFoam JLight OpenFOAM 0 December 16, 2010 12:46
Unexpected large decrease in Total temperature across the shock using sonicFoam JLight OpenFOAM Running, Solving & CFD 0 December 15, 2010 06:47
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
