Running chtMultiRegionFoam
Old   May 20, 2019, 11:00
Default Running chtMultiRegionFoam
Arslan Adeel Ur Rehmann
arslanadeel is on a distinguished road
Hi. I am trying to run some chtMultiRegion Simulations. Every tutorial follows as below:
blockMesh
topoSet
sliptMeshRegion
run Application
this is because they normally have one Mesh and then split them into MultiRegions.
However, in my case I already have two separate meshes, one for solid region and one for fluid region, I just put them into their respective constant/ploymesh directory and I am not using topoSet and splitMeshRegion commands. My check Mesh is ok on individual Meshes. however when I run the checkMesh on the same meshes in Multiregion case directory it fails.
I don't know whether the procedure I am doing is ok. Or I should try some other things.
arslanadeel is offline   Reply With Quote
Old   May 28, 2019, 12:01
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Your question is wide open and it may have many possibilities
Couple of questions.
How did you mesh?
Can you please post your "boundary" file from respective polyMesh folder?
What error do you get?
Regards
mwaqas is offline   Reply With Quote
#chtmultire #twomesh
Problem with running chtMultiRegionFoam after using setSet utility Victor OpenFOAM 12 March 24, 2023 01:01
Error in chtMultiRegionFoam michael157 OpenFOAM Running, Solving & CFD 17 May 22, 2017 04:32
Error in running case in chtMultiRegionFoam baran_foam OpenFOAM Programming & Development 3 July 7, 2015 05:38
Hypersonic Sim (running at Mach 7): floating point exception has occurred bungusbeefcake STAR-CCM+ 10 March 31, 2015 07:59
Fluent 14.0 file not running in parallel mode in cluster tejakalva FLUENT 0 February 4, 2015 08:02
