May 23, 2019, 08:35 |
#21 |
Ruiyan Chen
Rep Power: 10 |
I think the controlDict should be right now, because for steady-state simulations we set deltaT to 1, and endTime to the max number of iterations you want the solver to run for.
I took a brief look at your file, and still you have min/Max rho equals to 2.0 at the very beginning of the iterations. This value of 2.0 is what you set the maxRho to be. Therefore, this tells us that the actual density in your flow is already larger than 2.0. Any particular reason you are still bounding the densities? Since you are using rhoConst for the equation of state, what density did you set to your fluid? Also, after you ran checkMesh, note that you have high non-orthogonal regions, please improve your mesh as well. |
May 23, 2019, 09:59 |
#22 |
Raza Javed
Rep Power: 7 |
I am sorry I couldn't get exactly where I am bounding my density, because in the thermophysical properties of fluid, I set it to 1000. I am attaching my thermophysical properties of fluid below:
FoamFile { version 2.0; format ascii; class dictionary; location "constant/fluid"; object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } mixture { // Water specie { nMoles 1; molWeight 18; } equationOfState { rho 1000; } thermodynamics { Cp 4181; Hf 0; } transport { mu 959e-6; Pr 6.62; } } // ************************************************************************* // |
May 23, 2019, 22:38 |
#23 |
Ruiyan Chen
Rep Power: 10 |
In the SIMPLE entry of your fvSolutions file, you have rhoMin of 0.2 and rhoMax of 2.0. I think if you get rid of these your case should run smoothly. One more thing, in the same entry you have set pRefCell and pRefValue (we need these for incompressible flow, otherwise the solver doesn't know what pressure to use), I personally would recommend using pRefPoint instead of pRefCell, unless you know your reference point for the pressure is indeed in cell 0. for pRefPoint you can set the coordinate of the reference point, like (0.0 0.0 1.0).
Btw just out of curiosity, what fluids are you simulating, looks to me to be liquid water? |
May 24, 2019, 03:14 |
#24 |
Raza Javed
Rep Power: 7 |
Thank you for your reply.
I removed these two entries of rhoMin and rhoMax from fvSolution file, and then the solver runs for 76sec, and before it was running for 35sec. Then I changed the pRefCell to pRefPoint, but after that the solver still RUNS only for 76sec, and after that the same error comes. The log file is given below: Code:
Time = 74 Solving for fluid region fluid DILUPBiCG: Solving for Ux, Initial residual = 0.626649, Final residual = 0.04759457, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.5895491, Final residual = 0.03011316, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.4690052, Final residual = 0.03334807, No Iterations 2 DILUPBiCG: Solving for h, Initial residual = 0.5372248, Final residual = 0.01909215, No Iterations 2 Min/max T:175.3879 319.9405 GAMG: Solving for p_rgh, Initial residual = 0.601514, Final residual = 0.005827719, No Iterations 5 time step continuity errors : sum local = 76870, global = 3725.554, cumulative = -1018.419 Min/max rho:1000 1000 Solving for solid region box DICPCG: Solving for h, Initial residual = 0.01015602, Final residual = 0.0002773318, No Iterations 2 Min/max T:294.9693 301.3153 Solving for solid region plate1 DICPCG: Solving for h, Initial residual = 0.01482085, Final residual = 0.0001559468, No Iterations 2 Min/max T:300.1433 300.905 Solving for solid region plate2 DICPCG: Solving for h, Initial residual = 0.01324452, Final residual = 0.0001238401, No Iterations 2 Min/max T:300.146 300.9248 Solving for solid region plate3 DICPCG: Solving for h, Initial residual = 0.01349652, Final residual = 0.0001322007, No Iterations 2 Min/max T:300.1422 300.9191 ExecutionTime = 41.95 s ClockTime = 42 s Time = 75 Solving for fluid region fluid DILUPBiCG: Solving for Ux, Initial residual = 0.5524515, Final residual = 0.03745622, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.514814, Final residual = 0.02340077, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.410066, Final residual = 0.02328914, No Iterations 2 DILUPBiCG: Solving for h, Initial residual = 0.4178126, Final residual = 0.01453362, No Iterations 2 Min/max T:-34.34473 332.0189 GAMG: Solving for p_rgh, Initial residual = 0.7237737, Final residual = 0.005526134, No Iterations 4 time step continuity errors : sum local = 98527.33, global = 5650.649, cumulative = 4632.229 Min/max rho:1000 1000 Solving for solid region box DICPCG: Solving for h, Initial residual = 0.01065494, Final residual = 0.0004797391, No Iterations 2 Min/max T:285.1992 302.3668 Solving for solid region plate1 DICPCG: Solving for h, Initial residual = 0.01462008, Final residual = 0.0001537349, No Iterations 2 Min/max T:300.1448 300.9088 Solving for solid region plate2 DICPCG: Solving for h, Initial residual = 0.01308332, Final residual = 0.0001222664, No Iterations 2 Min/max T:300.1475 300.9285 Solving for solid region plate3 DICPCG: Solving for h, Initial residual = 0.01334374, Final residual = 0.0001307139, No Iterations 2 Min/max T:300.1437 300.9227 ExecutionTime = 42.52 s ClockTime = 43 s Time = 76 Solving for fluid region fluid DILUPBiCG: Solving for Ux, Initial residual = 0.5800244, Final residual = 0.03650541, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.5799028, Final residual = 0.009888277, No Iterations 3 DILUPBiCG: Solving for Uz, Initial residual = 0.4281356, Final residual = 0.005665427, No Iterations 3 DILUPBiCG: Solving for h, Initial residual = 0.5357228, Final residual = 0.01507815, No Iterations 2 --> FOAM FATAL ERROR: Maximum number of iterations exceeded From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::rhoConst<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy>] in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:? #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:? #4 ? at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 ? at ??:? Aborted (core dumped) |
May 25, 2019, 04:16 |
#25 |
Ruiyan Chen
Rep Power: 10 |
I don't think the errors you are getting now is related to the fluid dynamics part of your problem, everything (velocity, pressure) looks good. The min/max density is 1000, which is the value you set. During every iteration, it takes about 1-2 iterations for the velocity to converge, and more iterations for the pressure to converge, which is typical. I think the problem is more about heat transfer, as you noticed in the output for Time = 75, you are getting negative temperatures. Also, your continuity errors are quite large, that's not good. The means your velocity field doesn't satisfy the divergence free condition.
As I mentioned, I'm not familiar with this particular solver you are using, but normally heat transfer involving only fluid and solid under normal conditions should be easy. I would start from lowering the URFs, especially for pressure (I normally use ~0.3). Another thing is, your mesh has cells that have very high non-orthogonality, you should refine your mesh as well (or use at least 1 nNonOrthogonalCorrectors). One way to check the problem is visualizing the results before the solver crashes, and identify suspicious locations. For example, which part is having negative temperatures? Another thing I would do is, instead of having 3 solid regions, how about we start from only 1? Hope others who are familiar with this solver can check out your case. I've never used this solver so maybe this solver needs some special tunes? Good luck, Ruiyan |
fluid, laminar, openfoam, turbulent |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Laminar and Turbulent flow of transient analysis | gbrajtm | Main CFD Forum | 0 | February 7, 2019 23:19 |
Turbulent or laminar flow | yansheng | STAR-CCM+ | 4 | July 1, 2016 17:53 |
Do formula for Laminar and Turbulent Flow Calculation formulae change with Fluid | Parag Gadgil | FLUENT | 0 | June 19, 2012 07:07 |
Can I use turbulent model to solve a laminar flow? | nikhil | FLUENT | 5 | February 1, 2011 10:42 |
