May 19, 2019, 09:27 |
flowRateInletVelocity and Pressure
Raza Javed
Rep Power: 7 |
Hello Everyone,
I have a question related to boundary conditions. I have a pipe in my geometry. And I know the flow-rate of a fluid at the inlet. So, I am using flowRateInletVelocity boundary condition for velocity at the inlet. But I don't know which boundary condition to put for velocity at outlet? Second, what type of boundary conditions are suitable for Pressure at inlet and outlet in this case? I don't have any particular requirement for pressure in my simulation. Any help is highly appreciated. Thank you |
May 19, 2019, 18:45 |
Joachim Herb
Rep Power: 22 |
For velocity put zeroGradient or inletOutlet at the outlet.
For pressure: zeroGradient at the inlet and fixedValue (or fixedMean) at the outlet. |
May 20, 2019, 03:18 |
Raza Javed
Rep Power: 7 |
Thank you so much for your reply.
I am using chtMultiRegionSimpleFoam and my OpenFoam version is 4.1. I have changed the boundary conditions as you suggested. But I am still getting an error. My problem is that when I change the values of velocity and pressure, my solver RUNS but after some iterations, it gives an error that "maximum number of iterations exceeded". And then I tried to reduce the time interval in the "controlDict" file, then my solver runs completely without error, but my final residual is too high that it doesn't seem to be converging. I am posting my solver log and my changeDictionaryDict (boundary conditions). if you can please have a look, I shall be very thankful because I am not able to interpret the log because I am new to OpenFoam. changeDictionaryDict File Code:
boundary { inlet { type patch; } outlet { type patch; } } U { internalField uniform (0 1e-3 0); boundaryField { inlet { type fixedValue;//flowRateInletVelocity;//pressureInletVelocity;// //volumetricFlowRate 0.2; //extrapolateProfile yes; value uniform (0 1e-3 0); } outlet { type inletOutlet;//zeroGradient;//// value $internalField;//uniform (0 0 0);// inletValue $internalField; } "fluid_to_box" { type noSlip; } } } T { internalField uniform 300; boundaryField { inlet { type fixedValue; value uniform 300;//$internalField; } outlet { type inletOutlet; value $internalField; inletValue $internalField; } "fluid_to_box" { type compressible::turbulentTemperatureCoupledBaffleMixed; Tnbr T; kappaMethod fluidThermo; value uniform 300; } } } epsilon { internalField uniform 0.01; boundaryField { inlet { type fixedValue; value uniform 0.01; } outlet { type inletOutlet; inletValue uniform 0.01; } ".*" { type epsilonWallFunction; value uniform 0.01; } } } k { internalField uniform 0.1; boundaryField { inlet { type inletOutlet; inletValue uniform 0.1; } outlet { type zeroGradient; value uniform 0.1; } ".*" { type kqRWallFunction; value uniform 0.1; } } } p_rgh { internalField uniform 0; boundaryField { inlet { type fixedFluxPressure;//zeroGradient; value uniform 0; } outlet { type fixedValue; value uniform 0; } ".*" { type fixedFluxPressure; value uniform 0; } } } p { internalField uniform 0; boundaryField { inlet { type zeroGradient; //value uniform 1; } outlet { type fixedValue; value uniform 0; } "fluid_to_.*" { type zeroGradient; } } } Log File Code:
Time = 4 Solving for fluid region fluid DILUPBiCG: Solving for Ux, Initial residual = 0.6911749, Final residual = 0.04280814, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.6577878, Final residual = 0.04376797, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.5181872, Final residual = 0.02078987, No Iterations 2 DILUPBiCG: Solving for h, Initial residual = 0.5998981, Final residual = 0.03528898, No Iterations 2 --> FOAM FATAL ERROR: Maximum number of iterations exceeded From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::rhoConst<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy>] in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:? #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:? #4 ? at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 ? at ??:? Aborted (core dumped) |
May 20, 2019, 08:20 |
Rishikesh
Rep Power: 10 |
Can you share log a little prior to Time=4? The final residuals for each variable seem to have a very high value and yet only 2 iterations are made to solve it. It might also help to look at the fvSolution dictionary where these controls are defined. |
May 20, 2019, 09:01 |
Raza Javed
Rep Power: 7 |
I try to explain my problem from the start. I am attaching my geometry with this. one image is the complete box and the other one is inside box.(3 blue long rectangles and one green pipe with inlet and outlet). I made this geometry on Salome, and then I imported in Openfoam using UNV file. Then I put my boundary conditions using system/region_name/changeDictionaryDict. My requirement is that I need to put some fix velocity at the inlet and there is a temperature change along the fluid region due to some hot plates working as heat sources outside the walls of fluid region. And then, I want to see the temperature change at the outlet of the fluid region. I don't have any particular requirement for pressure in my simulation. With these conditions, I want to check at which value of velocity does my simulation reaches the steady state? Also I defined my fluid to be laminar flow. Is it correct? My problem is that when I change the values of velocity and pressure, my solver RUNS but after some iterations, it gives an error that "maximum number of iterations exceeded". And then I tried to reduce the time interval in the "controlDict" file, then my solver runs completely without error, but my final residual is too high that it doesn't seem to be converging. And I have one question here is that, is it possible to model laminar flow in this type of pipe? because with the same boundary conditions, I have a small geometry as well and that is working without errors. Thank you |
May 28, 2019, 11:16 |
Hella Raza,
Please also attach your log file, fvSolution and controlDict to have better understanding about the problem. Regards |
boundary condition, pressure, velocity |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 20:05 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
Pressure loss Velocity coupling | CFXMUFFIN | CFX | 1 | February 6, 2016 04:43 |
Discharge of Pressure Vessel into Pipe with Regulator | gajowni2 | System Analysis | 0 | October 31, 2015 18:57 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
