boundary conditions for Velocity, Pressure and Temperature |
May 19, 2019, 07:20 |
Raza Javed
Rep Power: 7 |
Hello Everyone,
I am using chtMultiRegionSimpleFoam and my Openfoam version is 4.1. I have created geometry in Salome and and then imported the UNV file to Openfoam. My geometry consists of a pipe and three rectangular plates, and all these things are in one box. The rectangular plates are acting as a heat source which I made using fvOption. Now, the fluid will flow from the pipe, and due to these hot rectangular plates, the temperature of the fluid will change inside the pipe. At the inlet, I need to put the flow-rate of 5 litres/minutes. At the inltet, temperature could be room temperature. Now, My task is to see the temperature change at the outlet. I have put some boundary conditions for Velocity, Temperature and Pressure, at inlet, outlet and at the walls of pipe. But my solver is not converging. I am not getting which boundary conditions to use. I have tried putting flowRateInletVelocity, but I don't know which boundary conditions to put at other boundaries in this case? I am putting my geometry and boundary conditions with this post. I shall be very thankful, is someone can help me out in this. Thank you Code:
boundary { inlet { type patch; } outlet { type patch; } } U { internalField uniform (0 1e-3 0); boundaryField { inlet { type flowRateInletVelocity;//pressureInletVelocity;//fixedValue; volumetricFlowRate 0.066; extrapolateProfile yes; value $internalField;//uniform (0 1e-3 0); } outlet { type zeroGradient; //value uniform (0 0 0);//$internalField; } "fluid_to_box" { type noSlip; } } } T { internalField uniform 300; boundaryField { inlet { type fixedValue; value uniform 450;//$internalField; } outlet { type inletOutlet; value $internalField; inletValue $internalField; } "fluid_to_box" { type compressible::turbulentTemperatureCoupledBaffleMixed; Tnbr T; kappaMethod fluidThermo; value uniform 300; } } } epsilon { internalField uniform 0.01; boundaryField { inlet { type fixedValue; value uniform 0.01; } outlet { type inletOutlet; inletValue uniform 0.01; } ".*" { type epsilonWallFunction; value uniform 0.01; } } } k { internalField uniform 0.1; boundaryField { inlet { type inletOutlet; inletValue uniform 0.1; } outlet { type zeroGradient; value uniform 0.1; } ".*" { type kqRWallFunction; value uniform 0.1; } } } p_rgh { internalField uniform 0; boundaryField { inlet { type fixedFluxPressure;//zeroGradient; value uniform 0; } outlet { type fixedValue; value uniform 0; } ".*" { type fixedFluxPressure; value uniform 0; } } } p { internalField uniform 0; boundaryField { ".*" { type calculated; //value uniform 0; } } } |
boundary conditions, openfoam |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
