Floating point exception / underflow problems.
Old   May 15, 2019, 06:46
Default Floating point exception / underflow problems.
Florian
Archoncomando is on a distinguished road
Hello there,
I'm still having trouble with my cases. I'm simulating a Hydrofoil wing that's partly submerged in Water. I'm using LTSInterFoam.
I managed to get a converging simulation by making the boundary conditions at the outlet a little more restrictive. Next i tried changing the angle of attack of the hydrofoil to -1° and +1°.
However now all my simulations crash in less than 100 timesteps (out of a 2100 intended) always with the errorcode 136 which according to my "research" means its either and under/overflow or a floating point exception.
My guess is on the floating point exception.
However i don't know what i can do to avoid the floating point exception. CheckMesh usually gives me the all clear with less than 10 high non orthogonality faces. Given that my mesh contains between 20.000.000 and 60.000.000 cells i'm assuming that's not it.
My boundary conditions for the outlet are set like this:
alpha.water: fixedValue
nut: zeroGradient
omega: zeroGradient
p_rgh: fixedFluxPressure
U: fixedValue
Does anyone have any other ideas on what i could try? I'm using a university cluster so i can't really mess around with the openfoam installation to disable exceptiontrapping.
I'd be very grateful for any help. If there's any use for more detailed look at my files please let me know i just don't want to overcrowd the initial question.
Thanks in advance!
Archoncomando is offline   Reply With Quote
floating point exception, ltsinterfoam, openfoam 2.3.1
simpleFoam: floating point exception student666 OpenFOAM Running, Solving & CFD 9 March 13, 2016 19:23
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 20:28
Finished simulation doesn't start: floating point exception [Divide by zero] MaxCFD STAR-CCM+ 3 June 26, 2011 11:31
reactingFoam floating point exception pajofego OpenFOAM 0 November 6, 2010 18:29
Floating Point Exception (Underflow) Error ashish FLUENT 1 April 19, 2006 12:08
