Bubble rising problem - diverged
Old   May 15, 2019, 05:08
Unhappy Bubble rising problem - diverged
John
thintn222 is on a distinguished road
Hello all Foamers !
I'm doing a simulation evolved with bubble rising within a water domain at the moment. I met a serious problem about The Courant number keep bigger and bigger in each time step . Go with it is the max(magU) getting bigger and bigger too. I want to run the case at 200s time step and it diverged at around 2.5s .
I just use 90000 hexahedra number of cells , checkMesh is OK , i decrease the timestep even to 1e-10 it still diverged , i turned on the adjustableTimestep but it still had the same problem
One more thing I notice that the value of min(alpha1) suddenly decreased from 0 to -1e-9 . And when the value Max cell volume fraction is bigger than 1 with the min dense number of parces = 4 . It diverged immediately
Please help me out with this problem.! Below is my checkMesh log, fvSchemes and fvSolution and my boundary condition. Thanks so much for helping me!
checkMesh
Mesh stats
    faces:            276900
    internal faces:   263100
    cells:            90000
    faces per cell:   6
    boundary patches: 3
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     90000
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    inlet               36       49       ok (non-closed singly connected)
    outlet              900      961      ok (non-closed singly connected)
    walls               12864    12936    ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-0.075 -0.075 0) (0.075 0.075 0.5)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (-1.25066e-16 -1.31008e-17 1.48292e-18) OK.
    Max cell openness = 1.35525e-16 OK.
    Max aspect ratio = 1 OK.
    Minimum face area = 2.5e-05. Maximum face area = 2.5e-05.  Face area magnitudes OK.
    Min volume = 1.25e-07. Max volume = 1.25e-07.  Total volume = 0.01125.  Cell volumes OK.
    Mesh non-orthogonality Max: 0 average: 0
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 1.11023e-13 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
fvSolution:
solvers
    "alpha.water.*"
        nAlphaCorr      2;
        nAlphaSubCycles 2;
        cAlpha          1;
        MULESCorr       yes;
        nLimiterIter    2;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-10;//1e-7;
        relTol          0;
        maxIter         100;
    pcorr
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-10;//1e-5;
        relTol          0;
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-10;//1e-07;
        relTol          0.05;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "(U|k|epsilon).*"
        tolerance       1e-10;//1e-06;
        relTol          0;
    kinematicCloud:alpha
        solver          PCG;//GAMG;
        preconditioner  DIC;//
        relTol          0.01;
        smoother        GaussSeidel;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 400;
        agglomerator    faceAreaPair;
        mergeLevels     1;
PIMPLE
    momentumPredictor   no;//yes;//no;//yes;//no;
    nOuterCorrectors    2;
    nCorrectors         2;
    nNonOrthogonalCorrectors 1;
    pRefCell            0;
    pRefValue           0;
    residualControl
       "(p|U|k|omega)"
         tolerance 1e-4;
         relTol    0;
relaxationFactors
    equations
       ".*"               0.5 ;
fvSchemes:
ddtSchemes
    default         Euler;//backward;//Euler;//CrankNicolson 0.38;
gradSchemes
    default         Gauss linear;//cellLimited Gauss linear 1;
    //grad(U)         Gauss linear;//Gauss linear;
   // grad(p)         Gauss linear;//
divSchemes
    default         none;
    div(rhoPhi,U)               Gauss upwind;
    div(phi,alpha)              Gauss vanLeer01;//linear;//upwind;
    div(phirb,alpha)            Gauss linear;//interfaceCompression;//linear;
    div(alphaRhoPhic,k)         Gauss upwind;
    div(alphaRhoPhic,epsilon)   Gauss upwind;
    div((((alphac*rho)*nuEff)*dev2(T(grad(U))))) Gauss linear;
    div(phiGByA,kinematicCloud:alpha) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;//limited corrected 0.1;//uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;//limited corrected 0.1;//corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha.water;
alpha.water.org
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 1;
boundaryField
    inlet
            type            zeroGradient;
    outlet
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    walls
        type            zeroGradient;
p_rgh
dimensions          [ 1 -1 -2 0 0 0 0 ];
internalField       uniform 0;
boundaryField
    inlet
         type            fixedFluxPressure;
         value           uniform 0;
    outlet
        type            prghTotalPressure;
        p0              uniform 0;
        value           uniform 0;
    walls
        value           uniform 0;
U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type               fixedValue;
        value              uniform (0 0 0);
    outlet
        type                 pressureInletOutletVelocity;
        value               $internalField;
        inletValue         $internalField;
    walls
          type                 fixedValue;
thintn222 is offline   Reply With Quote
Old   May 15, 2019, 22:24
Default Update
John
Update :
I quited control the value of Courant number , but another problem appeared.
The value of Phase-1 volume fraction keep increasing in each timestep and when it > 1 and min(alpha1) is negative . The simulation crashed again in ~6s
Any idea how to control this value !
Please help me, any advice are really appreciate !
TwoPhaseEulerFoam - Bubble diameter size Problem BlnPhoenix OpenFOAM Running, Solving & CFD 8 September 17, 2019 16:59
Taylor bubble rising in vertical pipe mhb18191 STAR-CCM+ 0 May 14, 2019 16:16
rising bubble vof simulation in fluent vinita123 Main CFD Forum 2 December 21, 2015 08:40
bubble rising grid study problem! mreza_cfd OpenFOAM Verification & Validation 7 July 26, 2015 10:41
Coupled VOF and Multiphase Segregated Flow for a gas bubble problem?? EnronZhang STAR-CCM+ 1 December 19, 2013 09:41
