Setting up a transient case with laminar incompressible flow
Old   May 14, 2019, 06:41
Default Setting up a transient case with laminar incompressible flow
VentinS is on a distinguished road
Dear Foamers,
I am trying to set up a transient case. The velocity is slow: Re =17
The mesh is a 3D Mesh, basically a U-shaped channel. I never tried to solve a case in openFoam with transient conditions.
My setup is:
U:
Inlet : (0 -0.0076 0), everything else 0
p:
Outlet: fixedValue 0;
In the controldict:
adjustTimeStep is activated
max Co 1,
Solver is the pimpleFoam in the Piso-mode
What I am trying to achieve is something like that:
https://www.youtube.com/watch?v=jx3DQn33MHE
But the time steps are getting smaller and smaller my deltaT is about 1e-10.
And when I deactivate the maxCo and the timesteps, the courant number rises.
And the velocity profile doesn’t look like the video at all.
Shall I wait or is everything wrong?
Kind regards
VentinS is offline   Reply With Quote
Old   May 14, 2019, 07:01
anonymous
simrego is on a distinguished road
Hi!
Your outlet is a zeroGradient for U and the inlet is zeroGradient for p?
Try to use a bit smaller Co (maybe 0.8-0.9) to be sure you wont exceed 1.
What about your mesh? Run a checkMesh so if you have a really poor mesh it'll complaining!
simrego is offline   Reply With Quote
Old   May 14, 2019, 08:20
Hey,
Yeah, exactly, I've checked
Ok, I set the maxCo =0.8 but the timesteps are still getting smaller...
The Mesh is OK and the steady state worked fine...
Old   May 14, 2019, 08:34
anonymous
Can you share your case?
I'm out of guesses, and if no one will give you the right hint, I'll check it. It doesn't seems to be a hell complicated case.
Old   May 15, 2019, 05:25
Yeah sure,
It would be wonderful, because I am pretty stuck....
https://www.dropbox.com/s/m9kr4vzsm9...Daily.zip?dl=0
Thanks!
Old   May 16, 2019, 04:40
Robert
RobertHB is on a distinguished road
Try inletOutlet for your velocity outlet condition.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Old   May 16, 2019, 06:29
Hey,
I've tried it but the deltaT ist still around 2e-7.
Maybe I should start with a 2D case first....
Old   May 16, 2019, 06:35
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by VentinS View Post
Yeah sure,
Thanks!
i opened the mesh and it shows very very small volume of 1E-18 m3 types. Also does it really have those crumbles on the surface as this image shows.
arjun is offline   Reply With Quote
Old   May 16, 2019, 07:34
hmm.. I guess this small volumes are the result from trying to flatten the mesh in icem and also this crumbles. I guess I was lucky, that steady case worked...
But even when I chop off the unstructured part, the result remains the same.
Here is the "short" version, if it helps:
https://www.dropbox.com/s/3b47zh3xs7...short.zip?dl=0
Old   May 16, 2019, 17:12
anonymous
Hi!
Sorry for the late answer.
So I checked your case. inletOutlet can be a bit dangerous. You can have really unphysical results.
Your 1st case seems to be really weird. I mean the mesh. Also the max nonorthogonality is ~83 if i remember well, which is pretty high.
But I think the mesh is also problematic in the second case you provided. It seems to be nice, checkmesh -> no error, but my first guess was that the mesh is bad. So i made a really fast rubbish mesh with snappyHexMesh, and the case ran perfectly as it should.
I suggest you to recreate the mesh. Try to create a simpler mesh, or just a coarser one, and if it works refine it.
I also made some modifications in the files. You can find your modified case in the following link.
https://drive.google.com/file/d/1cV5...ew?usp=sharing
Again!!! This mesh is really ugly, and you should doublecheck everything in the provided case, maybe i did some silly thing, but it is working without any problems for me.
You should tighten the tolerances, etc. Also there is a comment in the fvSolution file, I haven't used the foundation OF for a long time and i had no more time for that so sorry for the crap case.
Old   May 19, 2019, 13:26
Thank you soooooo much!
I guess I was lucky that the steady case worked.
I'll try and report you back
And again sorry for your trouble!!!!!!!!!!!
Setting up a case for a plane plate in a longitudinal flow Chronique OpenFOAM Running, Solving & CFD 0 October 9, 2014 15:17
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 08:45
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
incompressible flow over laminar plate varunjain89 Main CFD Forum 1 March 4, 2010 07:58
3D Incompressible turbulent flow validation case Yu Main CFD Forum 2 April 4, 2008 04:13
