multiple externalCoupled boundaries for multiple variables
Old   May 14, 2019, 05:14
Default multiple externalCoupled boundaries for multiple variables
Gerry Kan's Avatar
Gerry Kan
Gerry Kan is on a distinguished road
Howdy Folks:
I am wondering if it is possible to apply the externalCoupled boundary condition on different boundaries for different variables.
As a hypothetical example, I have a simple round pipe (three boundaries), for which I have velocity, pressure and temperature fields (as functions of position and time) for the boundaries from an external code. Effectively, I would like to have the following boundary assignments:
inlet: externalCoupled velocity (zeroGradient pressure and temperature)
outlet: externalCoupled pressure (zeroGradient velocity and temperature)
pipe wall: externalCoupled temperature (noSlip velocity and zeroGradient pressure)
So I have two questions ...
1) do I need to keep a separate comms directory (i.e. patchPoints / patchFaces) for each of the variable, or can I use a common comms directory where all patchPoints / patchFaces for all boundaries are included? (I believe it is a yes, but I would like to have a second opinion / confirmation).
2) Is it possible to prescribe velocity and pressure as externalCoupled at both the inlet and outlet? The solver will eventually be compressible so it should be possible, but my experience / gut feeling tells me otherwise.
Thanks in advance, Gerry.
Gerry Kan is offline   Reply With Quote
Old   August 10, 2020, 05:42
Long Jiang
jianglong is on a distinguished road
Hi Gerry, I am facing the same problem as you. I need to couple two boundary patches for different variables. Have you solved this problem?
jianglong is offline   Reply With Quote
Old   August 13, 2020, 13:48
Gerry Kan's Avatar
Gerry Kan
Dear Jiang:
Kind of. I was busy with other things at the moment so I haven't got time to work on it. But again, I am building a new boundary condition based on that, which complicates matter a lot (and it forced me to go through the source code, and admittedly it was a very steep learning curve).
If you are just looking to couple OpenFOAM with another solver via file I/O as-is, the tutorial that came with OpenFOAM should be able to show you how to set it up. Of course you will need to write the file I/O interface.
Hope that helps, Gerry.
boundary conditions, external bc, externalcoupled, openfoam
Implicit vs. explicit treatment of variables at zero gradient outflow boundaries eltenedor Main CFD Forum 0 February 21, 2015 16:37
[General] Programmable Filter: when multiple inputs, how to verify which input is which? macfly ParaView 0 July 12, 2014 12:14
Using Variables from multiple Physics Continua in Field Function cwl STAR-CCM+ 3 November 4, 2013 17:23
Boundaries and conservative variables pankos Main CFD Forum 0 April 2, 2011 04:50
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
