Can't capture the wake recovery behind a wind turbine: Exact opposite happens! |
May 11, 2019, 13:49 |
Hüseyin Can Önel
Rep Power: 8 |
Hello all,
I am using Smagorinsky LES in a dual wind turbine simulation. I use almost the same LES properties as given here. The problem is, I expect to see the minimum axial velocity just after the rotor and it it increases as I go further downstream. Now if I use RANS k-e turbulence model, I pretty much get this. But with LES, the exact opposite happens, the recovery is so small (or maybe it does not even exist), the axial velocity can't get the chance to increase as it goes downstream and even slows down due to downstream turbine. I can see this in velocity profiles. I guess I am doing something wrong with the turbulence model but can not figure out what. Any ideas would be very helpful. Thanks in advance. |
May 14, 2019, 19:06 |
Luis Eduardo
Rep Power: 15 |
Hi hconel,
Is your domain just the picture you present or is it bigger? Have you tested one single turbine in a big domain to see how the wind flow behaves? In case you did it, could you post it? How is your mesh resolution and what is the size of your domain and turbine? Best Regards, Luis |
May 15, 2019, 02:42 |
#3 | |
Santiago Lopez Castano
Rep Power: 16 |
AutoGrid - Meshing wind turbine blade | Ko_Shine | Fidelity CFD | 6 | November 7, 2024 13:47 |
Meshing wind turbine including tower in AutoGrid | Ko_Shine | Fidelity CFD | 18 | November 13, 2019 09:18 |
Wind turbine analyses in OF - first steps / beginner / | cadcae | OpenFOAM Running, Solving & CFD | 3 | March 1, 2015 17:00 |
Vertical Axis Wind Turbine | atorninc | Main CFD Forum | 3 | March 6, 2013 05:38 |
how to simulate a wind turbine in a lateral wind? | mohammad | Main CFD Forum | 0 | January 2, 2011 04:08 |
