Transitional external flows & DES in openFOAM - HELP!!
Old   May 10, 2019, 07:53
Default Transitional external flows & DES in openFOAM - HELP!!
zx9cp is on a distinguished road
Hi all,
I am completely new to OpenFOAM and am doing some initial exploratory research to see if it is able to offer me the functionality I need. For reference I am a CFX user looking to move away from the commercial software approach!!
I am working on a project where I am interested in modelling flow over a relatively streamlined body with a very bluff surface appendage. I'm struggling to get good drag results for the appendage with a purely RANS based approach and am thinking that taking a DES approach might imporove things.... BUT, I need to attempt to capture boundary layer transition on the streamlined body in order to predict the total drag of the 'assembly' as reliably as possible.
I see in ANSYS that I can use k-w SST coupled with either a 1-equation or 2-equation transition model as the RANS part of the DES simulation but I cant find anything comparable in OpenFOAM.
Is it possible to do what I want to do in OpenFOAM or is there some alternative method? Sorry if I'm covering a topic thats already been discussed!!
Thanks
zx9cp is offline   Reply With Quote
Old   July 2, 2019, 19:07
D L
DLuo is on a distinguished road
What version of OpenFoam are you using? Starting from v1612 onwards they've included the 4-equation LCTM (Langtry-Menter) predictive transition model as kOmegaSSTLM
If you look in the tutorials under incompressible/simpleFoam/T3A there's an example of how to use it and also has some experimental data to compare against.
Good luck
DLuo is offline   Reply With Quote
des les, des turbulence model, external aerdynamics, transitional sst
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
Memory protection in OpenFOAM / combinig with FORTRAN botp OpenFOAM Programming & Development 2 February 15, 2016 13:25
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
experiences with DES for liquid flows? sgt_pepper Main CFD Forum 0 November 11, 2008 06:16
