Parallel processing trouble
Old   May 8, 2019, 04:16
Default Parallel processing trouble
odisha
SWAPNASRITA is on a distinguished road
I am using OpenFOAM-4.1 and dsmcFoam for my application.
I have my own solver which I have added to the dsmc library.
I had to change workstation and that is when the problem started with parallel processing.
In this new workstation, I get correct results with single processor.
But if I try to use parallel processing with 8,9 or 10 processor it does not work. It only works with 5, 7 or 12 processors
Case details:
I have a 200 X 200 X 1000 porous structure and I decompose it in the z direction only. Then I use dsmcReactionFoam (my own) to get concentration of gas flowing through the porous structure.
As it is a very specific kind of issue, I couldn't find any help online.
Any help would be appreciated.
SWAPNASRITA is offline   Reply With Quote
Old   May 20, 2019, 08:00
odisha
It was due to typecasting a variable wrong.. I initialised a varibale as scalar and it needed to be int.
dsmc, parallelisation
Parallel processing of OpenFOAM cases on multicore processor??? g.akbari OpenFOAM Running, Solving & CFD 31 November 1, 2017 10:25
foamMonitor in parallel processing foamingMouth OpenFOAM Running, Solving & CFD 0 September 15, 2016 10:44
parallel processing and dynamic mesh Anand FLUENT 0 January 9, 2009 16:52
bubbly flow and parallel processing mvee FLUENT 0 September 12, 2007 06:08
Question about ghost cells in parallel processing vishwas Main CFD Forum 3 March 12, 2006 22:46
