Fluid flow from a pipe
Old   July 24, 2019, 10:41
Raza Javed
Raza Javed is on a distinguished road
Originally Posted by alexeym View Post
You can. It would be better to make new mesh with lower non-orthogonality. You should use not only increased value of non-orthogonal correctors, but also specific discretisation schemes.
In general, does making the cell size smaller make the non-orthogonality get lower?
Raza Javed is offline   Reply With Quote
Old   July 24, 2019, 15:32
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
In general, no. In fact, reducing cell size can have opposite effect.
alexeym is offline   Reply With Quote
Old   July 25, 2019, 04:16
Raza Javed
Hi. actually when I had bigger cells, I was having the problem of aspect ratio and skewness as well. Then I reduced the cell size, and aspect ratio and skewness problem resolved, but still I was getting non-orthogonality.
I don't know how to reduce the non-orthogonality, my non-orthogonality is 86 degree.
I am using limited fvSchemes, but I didn't put nonOrthoCorrectors.
can putting nonOrthocorrectors help?
Old   July 25, 2019, 09:09
sheaker's Avatar
Oskar
sheaker is on a distinguished road
With non orthogonality 87 no non orthogonal correction would be enough.
First of all check this image:
As You can see non orthogonality is related more likely to triangular cells than rectangular cells. Try to improve Your mesh quality using different method. Especially try to use quadrangle mash if possible. I do not know which tool You are using for meshing but maybe some restrictions or smoothing would solve the problem.
Check Your mesh carefully for bad mesh and divide geometry to improve cells quality.
Best regards,
Oskar
sheaker is offline   Reply With Quote
Old   July 25, 2019, 09:53
Raza Javed
Best regards,
Oskar
Thank you so much for your reply.
I am using salome for meshing. Actually my geometry has around 26 different regions with different sizes and shapes. And I am using Netgen 1D-2D-3D, but I am not trying other parameters.
And one general question here, which meshing tool is better, Salome OR snappyHexMesh?
Thank you
chtmultiregionsimpefoam, fluid, openfoam, pipe
Pulsatile flow at inlet of pipe model amsys CFX 5 July 20, 2016 14:18
Unable to input fluid to flow in a hollow pipe Mrsimple CFD Freelancers 3 March 22, 2016 06:18
[snappyHexMesh] Pipe flow / Internal fluid dynamics with SnappyHexMesh denner OpenFOAM Meshing & Mesh Conversion 3 October 13, 2011 10:24
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 10:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
