Multiphase ramping functionality
Old   May 2, 2019, 03:30
Default Multiphase ramping functionality
Sita Drost
sita is on a distinguished road
Hi all,
I just found out about the velocity ramping functionality for multi-phase flow that was recently added (https://github.com/OpenFOAM/OpenFOAM...b9f829e4ec3ec4). It looks extremely useful, so thanks for adding!
I'm not quite sure how to use it though; I tried adding it to the DTCHull tutorial in interFoam:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  dev
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      binary;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (-1.668 0 0);
velocityRamping
        type        velocityRamping;
        active      on;
        selectionMode all;
        U           U;
        velocity    (-1.668 0 0);
        ramp
            type        quarterSineRamp;
            start       0;
            duration    400;
boundaryField
    atmosphere
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    inlet
        type            uniformFixedValue;
        uniformValue    scale;
        uniformValueCoeffs
            scale           quarterSineRamp;
            scaleCoeffs
                start           0;
                duration        400;
            value           constant (-1.668 0 0);
    outlet
        type            outletPhaseMeanVelocity;
        UnMean          1.668;
        ramp
            start        0;
            duration    400;
        alpha           alpha.water;
    bottom
        type            symmetryPlane;
    side
        type            symmetryPlane;
    midPlane
        type            symmetryPlane;
    hull
        type            movingWallVelocity;
As a reference, this is what 0/U originally looked like in this tutorial:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      binary;
    location    "0";
    object      U;
boundaryField
    atmosphere
    inlet
        type            fixedValue;
        value           uniform (-1.668 0 0);
    outlet
        UnMean          constant 1.668;
        alpha           alpha.water;
    bottom
        type            symmetryPlane;
    side
        type            symmetryPlane;
    midPlane
        type            symmetryPlane;
    hull
Clearly this wasn't the proper way to go about this; the simulation runs smoothly, but a spurious velocity patch shows up at t = 0, just below the free surface close to the inlet (see attached image, there's also one right behind the ship).
How should this new functionality be used exactly? Sorry if this is a silly/trivial question, but as this functionality is quite new, I couldn't find anything about it in the User Guide or elsewhere online, apart from the description on GitHub.
Thanks in advance,
Sita
sita is offline   Reply With Quote
Old   May 13, 2019, 06:02
Sita Drost
Does anyone have experience with this new functionality?
Also, can it be used in combination with local time stepping (this is what the DTCHull tutorial uses)?
Many thanks,
Sita
Old   May 15, 2019, 03:50
Sita Drost
In case anyone else is struggling with this: I contacted one of the developers of this velocity ramping functionality, and he kindly provided the explanation below.
You need to define ramping function for the velocity at three points: inlet (BC type waveVelocity), outlet (BC type outletPhaseMeanVelocity) and you need the velocityRamping fvOption (which was recently renamed to accelerationSource). You need to ensure, that you have same parameters (ramp type, start and duration) for inlet, outlet and fvOption. Chose a reasonable value for ramp duration, e.g. for the DTC tutorial 25 seconds should be fine. For ramp type I normally use "quarterSineRamp". I hope this helps for getting your simulation running. If not, I can provide you example files for the DTCHull tutorial. One more hint: if you use a recent version of OpenFOAM-dev, you need to patch the waveSuperpostion.C file, because the current implementation does not support most of the ramp types. Unfortunately they changed implementation, which now uses intergration method of the function1, which is not implented for most function types. Remove "- UMean_->integrate(0, t)" in method transformation in waveSuperposition.C (line 68). Of course with this patch you will get wrong results, if waves are included.
Old   September 10, 2019, 16:46
Bruno de Almeida Regina
Bruno_Kwothe is on a distinguished road
Hey there, Sita!
I am practically a newcomer to OpenFOAM and I find myself struggling with velocity ramps at this moment. This thread of yours really gave some light to the subject, but I still have a question: what to do with the internalField in ./0/U? How to set it?
Another thing that could be helpful: what other ramp types are there? Is linear ramp available?
I see you offered DTCHull tutorial with modified files... would you still be able to share them? I am interested
Anyhow, thanks in advance for the attention and sorry for any trouble.
Kind regards,
Bruno
Bruno_Kwothe is offline   Reply With Quote
Old   September 11, 2019, 03:46
Sita Drost
Hi Bruno,
To be honest I'm not much of an expert on this, if you really want to know how things work with velocity ramping, better contact one of the developers.
What seems to be working for me at the moment is something like the attached 0/U and constant/fvOptions files, although I'm still fine-tuning the required duration (too short causes huge waves to appear at the inlet and outlet). For a model-scale ship a few seconds is alright, but for a full-scale ship you clearly need longer.
I must admit I haven't tried using different ramp types yet. From a quick glance at the source files I gathered that there should be at least also a half cosine ramp. Have you tried the banana trick yet? That is, instead of quarterSineRamp, enter banana (or whatever other clearly incorrect word) in your dictionary files. OpenFOAM will then throw an error, and if you're lucky, it will list the valid ramp types. If not, rooting through the source files might help. Or just enter "linear", who knows, you might be lucky.
About the modified tutorial, that was one of the developers offering that, so if you think you need that, better contact one of the developers.
Hope this helps,
Sita
Old   September 17, 2019, 19:06
Hi again, Sita!
Thank you for your files! I got caught up in other analyses and just now I am having time to test the ramp functionality.
I must confess, I was so excited with that previous message of yours that I did not realize it was the developer who offered the DTCHull files! But that's ok. Speaking of the developers, how did you contact them? Do you still have their contact?
Once again, thank you for the attention and sorry for the troubles!
Bruno
Old   September 18, 2019, 02:50
Sita Drost
Hi Bruno,
That's no problem. The names of the developers are in the GitHub post about the ramping functionality (https://github.com/OpenFOAM/OpenFOAM...b9f829e4ec3ec4), so I just Googled them. I'm a bit reluctant to share someone else's contact information here, but I'm sure you'll figure it out.
Best wishes,
Sita
Old   September 18, 2019, 14:03
Okay, Sita!
Thank you for the tips!
How to simulate the eulerian multiphase model about particle jhlee9622 STAR-CCM+ 2 November 24, 2016 12:37
The problem of Stiff Chemistry Solver in Multiphase model shenzhou1987 FLUENT 1 January 11, 2016 03:52
Multiphase Simulation - Fluent vinayak4399 Fluent Multiphase 3 December 13, 2015 12:46
Low Mach Number Compressible Multiphase Flows DarrenC CFX 10 May 26, 2014 09:52
transportProperties-syntax in 1.6 (ramping) utwaz OpenFOAM 0 November 20, 2009 12:41
