topoSet and fvOptions
Old   April 30, 2019, 08:43
Default topoSet and fvOptions
Raza Javed
Raza Javed is on a distinguished road
Hello Everyone,
My OpenFoam version is 4.1
I am using fvOptions to generate a heat source. My fvOptions file is given below:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      porousZone;
heatSource
    type            scalarSemiImplicitSource;
    active          true;
    scalarSemiImplicitSourceCoeffs
        selectionMode   cellSet; // all, cellSet, cellZone, points
        //cellZone        Hot_box;
        cellSet         hotFaceCellSet;
        volumeMode      absolute; // specific;
        injectionRateSuSp
            h     (1000 0);
I am using the cellSet option and for that I am using topoSetDict, to generate first the faceSet and then from that faceSet to cellSet. My topoSetDict is given below:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
    // wall
        name    hot;
        type    faceSet;
        action  new;
        source  patchToFace;
        sourceInfo
            name "hotFace";
// Select based on faceSet
        name    hotFaceCellSet;
        type      cellSet;
        action    new;
        source   faceToCell;
        sourceInfo
            set hot;             // Name of faceSet
       //option neighbour; // cell with neighbour in faceSet
        //option owner;     //  ,,       owner
            option any;         // cell with any face in faceSet
       //option all;       // cell with all faces in faceSet
This topoSetDict file is creating my faceSet and cellSet both. My log file for topoSet is given below:
Create time
Create polyMesh for time = 0
Reading topoSetDict
Time = 0
    mesh not changed.
Created faceSet hot
    Applying source patchToFace
    Adding all faces of patch hotFace ...
    Found matching patch hotFace with 1092 faces.
    faceSet hot now size 1092
Created cellSet hotFaceCellSet
    Applying source faceToCell
    Adding cells according to faceSet hot ...
    cellSet hotFaceCellSet now size 1092
 End
But I am getting the following error:
Creating finite volume options from "constant/fvOptions"
Selecting finite volume options model type scalarSemiImplicitSource
    Source: heatSource
    - selecting cells using cellSet hotFaceCellSet
--> FOAM FATAL ERROR:
Illegal content 4105 of set:hotFaceCellSet of type cellSet
Value should be between 0 and 3956
    From function void Foam::topoSet::check(Foam::label)
    in file sets/topoSets/topoSet.C at line 189.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::topoSet::check(int) at ??:?
#3  Foam::cellSet::cellSet(Foam::polyMesh const&, Foam::word const&, Foam::IOobject::readOption, Foam::IOobject::writeOption) at ??:?
#4  Foam::fv::cellSetOption::setCellSet() at ??:?
#5  Foam::fv::cellSetOption::cellSetOption(Foam::word const&, Foam::word const&, Foam::dictionary const&, Foam::fvMesh const&) at ??:?
#6  Foam::fv::option::adddictionaryConstructorToTable<Foam::fv::SemiImplicitSource<double> >::New(Foam::word const&, Foam::word const&, Foam::dictionary const&, Foam::fvMesh const&) at ??:?
#7  Foam::fv::option::New(Foam::word const&, Foam::dictionary const&, Foam::fvMesh const&) at ??:?
#8  Foam::fv::optionList::reset(Foam::dictionary const&) at ??:?
#9  Foam::fv::optionList::optionList(Foam::fvMesh const&, Foam::dictionary const&) at ??:?
#10  Foam::fv::options::options(Foam::fvMesh const&) at ??:?
#11  ? at ??:?
#12  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13  ? at ??:?
Aborted (core dumped)
I am not getting why I am getting this error? Or I am making some other mistake?
I shall be very thankful if someone can help me out in this.
Raza Javed is offline   Reply With Quote
Old   February 4, 2020, 15:44
bashirm90 is on a distinguished road
Did you ever figure out how to fix that issue? I am running into the same problem.
bashirm90 is offline   Reply With Quote
cellset, fvoptions, openfoam, toposet
topoSet/setSet and fvOptions pod OpenFOAM Running, Solving & CFD 5 April 30, 2019 06:41
rhoPimpleFoam & fvOptions - defined but not applied bullmut OpenFOAM Running, Solving & CFD 6 April 11, 2019 11:55
fvOptions, faceZone, directionalPressureGradientExplicitSource Alasir OpenFOAM Running, Solving & CFD 0 November 24, 2017 06:04
Using fvOptions for Heat Source in CellSets toro-boro OpenFOAM Running, Solving & CFD 1 March 9, 2017 03:43
[snappyHexMesh] Porous Media using TopoSet RobertoCirolini OpenFOAM Meshing & Mesh Conversion 3 August 30, 2016 09:34
