2-Phase Hydrofoil simulation keeps diverging.
Old   April 29, 2019, 10:24
Default 2-Phase Hydrofoil simulation keeps diverging.
Florian
Archoncomando is on a distinguished road
Hell there,
I'm trying to simulate a curved Hydrofoil that is partly submerged in Water.
However i can't get the forces acting on the hydrofoil to converge. They start at a very low number (-30k) Newtons, then rise up to around 1300 - 1700 (Which is around the expected value), stay there for a while then go all the way up to insane values like 10^44 Newton.
I'm running the simulation in OpenFOAM-2.3.1 using LTSInterFoam. I've tried having the outlet as zeroGradient as well as fixedValue.
I've also tried different maxCo values but those still diverged. Does anyone have an idea what other factors i could play around with?
One thing i noticed is that when i introduce stream tracers to the results they seem as expected for the submerged and dry areas but the water surface seems very erratic.
Would it help to share my config files for the case? If so can someone recommend a good way to do it? Just copy pasting them into this post seems like it would be very tedious for you to look at them.
Greetings and thanks in advance
Florian
Archoncomando is offline   Reply With Quote
2 phase flow, divergent, hydrofoil, hydrofoil lift, openfoam 2.3.1
simulation two phase closed thermosyphon mohammad reza FLUENT 3 November 1, 2016 04:58
Diverging simulation czhongrong OpenFOAM Running, Solving & CFD 45 November 21, 2015 08:17
Simulation of Phase change material (PCM) and nanoparticles together farah Main CFD Forum 0 November 2, 2015 15:30
a question about two phase simulation xck1986 OpenFOAM Running, Solving & CFD 0 June 16, 2011 12:00
Three phase simulation of airlift reactor Idtisak CFX 0 February 22, 2008 11:05
