SetFields for LES simulation
Old   April 29, 2019, 07:11
Default SetFields for LES simulation
Andrea Belle'
belleandrea is on a distinguished road
Hello. I am running a LES simulation on a simple square pipe geometry using PisoFoam as solver. I would like to initialize some turbulence setting some different initial values of the velocity fields in different regions of my geometry using SetFieldsDict.
Without using SetFields, the simulation works properly. If I use SetFields, I get this error, and I do not understand what I should do to solve the problem. Thank you in advance.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
Build : 6-e29811f5dff8
Exec : pisoFoam
Date : Apr 29 2019
Time : 11:55:41
Host : "lrspc49"
PID : 15432
I/O : uncollated
Case : /home/andrea/Desktop/pitzDaily
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type LES
Selecting LES turbulence model dynamicKEqn
Selecting LES delta type cubeRootVol
--> FOAM Warning :
From function void Foam::LESModels::cubeRootVolDelta::calcDelta()
in file LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C at line 55
Case is 2D, LES is not strictly applicable
bounding k, min: 0 max: 2e-05 average: 0
dynamicKEqnCoeffs
filter simple;
Ce 1.048;
No MRF models present
No finite volume options present
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5 Foam::LESModels::dynamicKEqn<Foam::IncompressibleT urbulenceModel<Foam::transportModel> >::Ck(Foam::GeometricField<Foam::SymmTensor<double >, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
#6 Foam::LESModels::dynamicKEqn<Foam::IncompressibleT urbulenceModel<Foam::transportModel> >::correctNut(Foam::GeometricField<Foam::SymmTenso r<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#7 Foam::LESModels::dynamicKEqn<Foam::IncompressibleT urbulenceModel<Foam::transportModel> >::correctNut() at ??:?
#8 ? at ??:?
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10 ? at ??:?
Floating point exception (core dumped)
belleandrea is offline   Reply With Quote
Old   April 30, 2019, 05:14
Robert
RobertHB is on a distinguished road
A Floating Point Exception often results from a division by zero. Without further information about your variables i'd guess that either the set velocity values is far to larger and instantly breaks the Courant number or one of the turbulence variables is far to small.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Convergence Problem - Transient Simulation gemxx Main CFD Forum 0 July 15, 2018 10:36
Mapping Field Data for Mesh Regions from Another Simulation veterator OpenFOAM Pre-Processing 1 July 10, 2018 06:28
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 03:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 16:06
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 04:16
