OF v1612+ boundary mesh definitions versus 0 folder
Old   April 26, 2019, 17:52
Default OF v1612+ boundary mesh definitions versus 0 folder
B. Assaad
bassaad17 is on a distinguished road
Hi Folks,
I'm having an issue that I can't figure out how to solve. I'm using Grasshopper/Butterfly to create a first pass of my OF Case setup for v1612+.
I'm simulating wind flow in an urban environment for tall buildings. I have a 6 sided cube with the flow direction incoming form the North (negative y axis).
I'm able to run blockMesh, checkMesh, surfaceFeatureExtract, decomposePar, snappyHexMesh (24 cpu's), reconstructParMesh .. When I go to run decomposePar I receive this FOAM FATAL IO ERROR
Time = 0
--> FOAM FATAL IO ERROR:
    patch type 'wall' not constraint type 'symmetry'
    for patch Side_270 of field k in file "/Projects/TestCase/Run_N_01-2/0/k"
file: /Projects/TestCase/Run_N_01-2/0/k.boundaryField.Side_270 from line 36 to line 36.
    From function Foam::symmetryFvPatchField<Type>::symmetryFvPatchField(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = double]
    in file fields/fvPatchFields/constraint/symmetry/symmetryFvPatchField.C at line 56.
FOAM exiting
My 0/k is defined as follows:
|  \\    /   O peration     | Version:  v1612+                                |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
/* Butterfly 0.0.4                https://github.com/ladybug-tools/butterfly *\
FoamFile
	version		4.0;
	format		ascii;
	class		volScalarField;
	location	"0";
	object		k;
dimensions		[0 2 -2 0 0 0 0];
internalField		uniform 0.02;
boundaryField
    Top
        type		slip;
    Side_270
        type		symmetry;
    Side_180
        type		zeroGradient;
    Terraces
        type		kqRWallFunction;
        value		$internalField;
    Far_Ground
    Close_Buildings_and_Target
    Surroundings
    Side_090
        type		symmetry;
    Side_000
        type		fixedValue;
    Close_Ground
I was able to identify that the constant/polyMesh boundary file has everything define as walls - and that must be the source of the error
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
11
    boundingbox
        type            wall;
        inGroups        1(wall);
        nFaces          11;
        startFace       50471483;
    Side_000
        type            wall;
        inGroups        1(wall);
        nFaces          22930;
        startFace       50471494;
    Side_180
        type            wall;
        inGroups        1(wall);
        nFaces          22930;
        startFace       50494424;
    Side_090
        type            wall;
        inGroups        1(wall);
        nFaces          22930;
        startFace       50517354;
    Side_270
        type            wall;
        inGroups        1(wall);
        nFaces          22930;
        startFace       50540284;
    Terraces
        type            wall;
        inGroups        1(wall);
        nFaces          33879;
        startFace       50563214;
    _53StateStMesh018_Close_Ground
        type            wall;
        inGroups        1(wall);
        nFaces          50197;
        startFace       50597093;
    _53StateStMesh018_Far_Ground
        type            wall;
        inGroups        1(wall);
        nFaces          62431;
        startFace       50647290;
    Top
        type            wall;
        inGroups        1(wall);
        nFaces          68073;
        startFace       50709721;
        type            wall;
        inGroups        1(wall);
        nFaces          152814;
        startFace       50777794;
    Surroundings
        type            wall;
        inGroups        1(wall);
        nFaces          205497;
        startFace       50930608;
What do I need to be doing to make sure that the 'boundary' file is picking up the right conditions as defined in my k, nut, omega, p, U files in the 0 folder.
Please advise. Thank you.
bassaad17 is offline   Reply With Quote
Old   April 27, 2019, 10:24
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
You can use changeDictionary utility to change boundary file. Set type of Side_090 and Side_270 to symmetryPlane. Alternatively, you can edit boundary file by hand.
alexeym is offline   Reply With Quote
Old   May 2, 2019, 11:59
B. Assaad
Hi alexeym ... I ended up manually editing the 'boundary' file by assigning its proper conditions and the model kicked off fine using simpleFoam thereafter. Thank you.
BA
boundary, butterfly, openfoam, v1612+
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 06:53
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues nathanricks ANSYS Meshing & Geometry 0 September 23, 2015 06:14
