'mesh' was not declared in this scope
Old   April 25, 2019, 14:28
Default 'mesh' was not declared in this scope
shanvach is on a distinguished road
Hi all,
I am trying to add a new particle force in src/lagrangian/intermediate/submodels/Kinematic/ParticleForces
In the formulation I want to use wallDist(mesh) to calculate the vector perpendicular to the wall.
I added #include "wallDist.H" and the following is .C file
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | Copyright (C) 2011-2016 OpenFOAM Foundation
     \\/     M anipulation  |
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
#include "MicroLift.H"
//#include "createMesh.H"
#include "mathematicalConstants.H"
#include "fundamentalConstants.H"
#include "demandDrivenData.H"
#include "turbulenceModel.H"
#include "wallPointData.H"
using namespace Foam::constant;
// * * * * * * * * * * * * Private Member Functions  * * * * * * * * * * * * //
template<class CloudType>
Foam::scalar Foam::MicroLift<CloudType>::erfInv(const scalar y) const
    const scalar a = 0.147;
    scalar k = 2.0/(mathematical::pi*a) +  0.5*log(1.0 - y*y);
    scalar h = log(1.0 - y*y)/a;
    scalar x = sqrt(-k + sqrt(k*k - h));
    if (y < 0.0)
        return -x;
    else
        return x;
Foam::tmp<Foam::volScalarField>
Foam::MicroLift<CloudType>::kModel() const
    const objectRegistry& obr = this->owner().mesh();
    const word turbName =
        IOobject::groupName
            turbulenceModel::propertiesName,
            this->owner().U().group()
    if (obr.foundObject<turbulenceModel>(turbName))
        const turbulenceModel& model =
            obr.lookupObject<turbulenceModel>(turbName);
        return model.k();
    else
        FatalErrorInFunction
            << "Turbulence model not found in mesh database" << nl
            << "Database objects include: " << obr.sortedToc()
            << abort(FatalError);
        return tmp<volScalarField>(nullptr);
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::MicroLift<CloudType>::MicroLift
    CloudType& owner,
    const fvMesh& mesh,
    const dictionary& dict
    ParticleForce<CloudType>(owner, mesh, dict, typeName, true),
    rndGen_(owner.rndGen()),
    lambda_(readScalar(this->coeffs().lookup("lambda"))),
    turbulence_(readBool(this->coeffs().lookup("turbulence"))),
    kPtr_(nullptr),
    ownK_(false)
    const MicroLift& bmf
    ParticleForce<CloudType>(bmf),
    rndGen_(bmf.rndGen_),
    lambda_(bmf.lambda_),
    turbulence_(bmf.turbulence_),
    kPtr_(nullptr),
    ownK_(false)
// * * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * //
Foam::MicroLift<CloudType>::~MicroLift()
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
void Foam::MicroLift<CloudType>::cacheFields(const bool store)
    if (turbulence_)
        if (store)
            tmp<volScalarField> tk = kModel();
            if (tk.isTmp())
                kPtr_ = tk.ptr();
                ownK_ = true;
            else
                kPtr_ = &tk();
                ownK_ = false;
        else
            if (ownK_ && kPtr_)
                deleteDemandDrivenData(kPtr_);
                ownK_ = false;
Foam::forceSuSp Foam::MicroLift<CloudType>::calcCoupled
    const typename CloudType::parcelType& p,
    const scalar dt,
    const scalar mass,
    const scalar Re,
	//const scalar uc,
    const scalar muc
) const
    forceSuSp value(Zero, 0.0);
    const scalar dp = p.d();
	const vector uc = p.Uc();
	const scalar rhoc = p.rhoc();
	const scalar h = 100e-6;
    const scalar Tc = 310.5;
	scalar f = 0;
	f = rhoc*mag(uc)*mag(uc)*dp*dp*dp*dp/(h*h);
	const label celli = p.cell();
	volScalarField dis = wallDist(mesh).y();
	volVectorField ncap = wallDist(mesh).n();
	scalar gauss_x = ncap[celli].x();
	scalar gauss_y = ncap[celli].y();
	scalar gauss_z = ncap[celli].z();
	const vector dir(gauss_x, gauss_y, gauss_z);
	value.Su() = f*dir;
//	Random& rnd = this->owner().rndGen();
    return value;
I am getting the following error
lnInclude/MicroLift.C: In member function ‘virtual Foam::forceSuSp Foam::MicroLift<CloudType>::calcCoupled(const typename CloudType::parcelType&, Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar) const’:
lnInclude/MicroLift.C:184:32: error: ‘mesh’ was not declared in this scope
lnInclude/MicroLift.C: In instantiation of ‘Foam::forceSuSp Foam::MicroLift<CloudType>::calcCoupled(const typename CloudType::parcelType&, Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar) const [with CloudType = Foam::KinematicCloud<Foam::Cloud<Foam::KinematicParcel<Foam::particle> > >; typename CloudType::parcelType = Foam::KinematicParcel<Foam::particle>; Foam::scalar = double]’:
parcels/derived/basicKinematicParcel/makeBasicKinematicParcelSubmodels.C:48:49:   required from here
lnInclude/MicroLift.C:180:18: warning: unused variable ‘Tc’ [-Wunused-variable]
shanvach is offline   Reply With Quote
Old   April 26, 2019, 09:05
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
The error is quite self-explanatory. There is no mesh variable, declared in the method. You can access mesh thought mesh method of the parent class. So your code should be something like:
	volScalarField dis = wallDist(mesh()).y();
	volVectorField ncap = wallDist(mesh()).n();
alexeym is offline   Reply With Quote
Old   April 26, 2019, 13:47
Hi Alexey,
Thank you for your response.However when I used mesh() instead of mesh, I got the following error:-
In file included from lnInclude/MicroLift.H:162:0,
                 from lnInclude/makeParcelForces.H:49,
                 from parcels/derived/basicKinematicParcel/makeBasicKinematicParcelSubmodels.C:31:
lnInclude/MicroLift.C:184:37: error: there are no arguments to ‘mesh’ that depend on a template parameter, so a declaration of ‘mesh’ must be available [-fpermissive]
lnInclude/MicroLift.C:184:37: note: (if you use ‘-fpermissive’, G++ will accept your code, but allowing the use of an undeclared name is deprecated)
lnInclude/MicroLift.C:185:38: error: there are no arguments to ‘mesh’ that depend on a template parameter, so a declaration of ‘mesh’ must be available [-fpermissive]
make: *** [Make/linux64GccDPInt32Opt/parcels/derived/basicKinematicParcel/makeBasicKinematicParcelSubmodels.o] Error 1
Am I using the member function mesh() improperly?
Your help in this matter is greatly appreciated.
Thanks and Regards,
Shantanu Vachhani
Old   April 26, 2019, 17:24
Alexey Matveichev
In fact, you have two choices:
1. Since class constructor receives constant fvMesh reference as a parameter, you can create my_lovely_mesh_ property in MicroLift class, initialise it in the constructor, and then use it in any method of the class.
2. In general, in ParticleForce children mesh is accessed as this->mesh().
icouncoupledkinematic, lagrangian, mesh, particle forces, walldist patch distance
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 11:05
Problem running perturbUCyl sen.1986 OpenFOAM 17 June 4, 2019 06:56
erros when compiling simpleSRFFoam examosty OpenFOAM Installation 12 April 26, 2010 19:53
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
