magneticFoam problem
Old   April 24, 2019, 19:56
Default magneticFoam problem
Luis Lencina
LUIS1717 is on a distinguished road
Hi everyone,
I am trying to solve a magnetic problem with openfoam 1812, I download a case file that i found in the forum, and i found some problems with the code and the input. I attach both.
The problem that i cannot solve is that the facezones generated by toposet program use the global index of the mesh. When i try to set the surfacescalarfield murf usign the operator[] it only contains the internal surfacemesh, so it try to write outside the vector lenght.
i add this lines to createFields.H
Info<<"mesh "<<mesh.faces().size()<<endl;
Info<<"murf "<<murf.size()<<endl;
and the output is
mesh 40200
murf 19800
so the program crash when it try to set a face beyond 19800.
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in /lib64/libc.so.6
#3 Foam:ICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) at ??:?
#4 Foam:ICPreconditioner:ICPreconditioner(Foam::l duMatrix::solver const&, Foam::dictionary const&) at ??:?
#5 Foam::lduMatrix:reconditioner::addsymMatrixConst ructorToTable<Foam:ICPreconditioner>::New(Foam:: lduMatrix::solver const&, Foam::dictionary const&) at ??:?
#6 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) at ??:?
#7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#8 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#9 Foam::fvMatrix<double>::solveSegregatedOrCoupled(F oam::dictionary const&) at ??:?
#10 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:?
#11 ? at ??:?
#12 __libc_start_main in /lib64/libc.so.6
#13 ? at ??:?
Floating point exception (core dumped)
Can anyone help me?
thanks
LUIS1717 is offline   Reply With Quote
Old   April 28, 2019, 09:00
Luis Lencina
Well, now I understand the problem, the first nodes are always the internal faces, then there are the boundary faces. I don't know how to set the boundary nodes, but i change this and it works
forAll(magnets, i)
label magnetZonei = mesh.faceZones().findZoneID(magnets[i].name());
if (magnetZonei == -1)
FatalIOErrorInFunction(transportProperties)
<< "Cannot find faceZone for magnet " << magnets[i].name()
<< exit(FatalIOError);
const labelList& faces = mesh.faceZones()[magnetZonei];
const scalar muri = magnets[i].mur();
const scalar Mri = magnets[i].Mr().value();
const vector& orientationi = magnets[i].orientation();
const surfaceVectorField& Sf = mesh.Sf();
forAll(faces, i)
label facei = faces[i];
if(facei < murf.size()){
murf[facei] = muri;
Mrf[facei] = Mri*(orientationi & Sf[facei]);
magneticfoam, surfacescalarfields
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
