April 24, 2019, 10:36 |
MPI warnings
Sita Drost
Rep Power: 18 |
Hi all,
I'm using OpenFOAM-5.x on a Scientific Linux cluster. Whenever I run a case in parallel (np = 12), I get some MPI-related warnings. One from OpenFOAM: Code:
--> FOAM Warning : From function static bool Foam::UPstream::init(int&, char**&) in file UPstream.C at line 99 mpi does not seem to have thread support. There might be issues with e.g. threaded IO Code:
11 more processes have sent help message help-mpi-btl-openib-cpc-base.txt / no cpcs for port [upwind3:21943] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Many thanks, Sita EDIT: I finally found the rest of the warnings (the ones preceding the "11 more processes have sent help message..." warning): Code:
water.29115hfi_wait_for_device: The /dev/hfi1_0 device failed to appear after 15.0 seconds: Connection timed out water.29113hfi_wait_for_device: The /dev/hfi1_0 device failed to appear after 15.0 seconds: Connection timed out water.29119hfi_wait_for_device: The /dev/hfi1_0 device failed to appear after 15.0 seconds: Connection timed out water.29114hfi_wait_for_device: The /dev/hfi1_0 device failed to appear after 15.0 seconds: Connection timed out water.29117hfi_wait_for_device: The /dev/hfi1_0 device failed to appear after 15.0 seconds: Connection timed out water.29112hfi_wait_for_device: The /dev/hfi1_0 device failed to appear after 15.0 seconds: Connection timed out water.29123hfi_wait_for_device: The /dev/hfi1_0 device failed to appear after 15.0 seconds: Connection timed out water.29118hfi_wait_for_device: The /dev/hfi1_0 device failed to appear after 15.0 seconds: Connection timed out water.29120hfi_wait_for_device: The /dev/hfi1_0 device failed to appear after 15.0 seconds: Connection timed out water.29122hfi_wait_for_device: The /dev/hfi1_0 device failed to appear after 15.0 seconds: Connection timed out water.29116hfi_wait_for_device: The /dev/hfi1_0 device failed to appear after 15.0 seconds: Connection timed out water.29121hfi_wait_for_device: The /dev/hfi1_0 device failed to appear after 15.0 seconds: Connection timed out [water][[11549,1],2][btl_openib.c:880:mca_btl_openib_add_procs] could not prepare openib device for use -------------------------------------------------------------------------- The OpenFabrics (openib) BTL failed to initialize while trying to allocate some locked memory. This typically can indicate that the memlock limits are set too low. For most HPC installations, the memlock limits should be set to "unlimited". The failure occured here: Local host: water OMPI source: btl_openib.c:794 Function: ompi_free_list_init_ex_new() Device: mlx4_0 Memlock limit: 65536 You may need to consult with your system administrator to get this problem fixed. This FAQ entry on the Open MPI web site may also be helpful: http://www.open-mpi.org/faq/?category=openfabrics#ib-locked-pages -------------------------------------------------------------------------- [water][[11549,1],10][btl_openib.c:880:mca_btl_openib_add_procs] could not prepare openib device for use [water][[11549,1],8][btl_openib.c:880:mca_btl_openib_add_procs] could not prepare openib device for use [water][[11549,1],1][btl_openib.c:880:mca_btl_openib_add_procs] could not prepare openib device for use [water][[11549,1],6][btl_openib.c:880:mca_btl_openib_add_procs] could not prepare openib device for use [water][[11549,1],7][btl_openib.c:880:mca_btl_openib_add_procs] could not prepare openib device for use [water][[11549,1],3][btl_openib.c:880:mca_btl_openib_add_procs] could not prepare openib device for use [water][[11549,1],9][btl_openib.c:880:mca_btl_openib_add_procs] could not prepare openib device for use [water][[11549,1],5][btl_openib.c:880:mca_btl_openib_add_procs] could not prepare openib device for use [water][[11549,1],11][btl_openib.c:880:mca_btl_openib_add_procs] could not prepare openib device for use [water][[11549,1],4][btl_openib.c:880:mca_btl_openib_add_procs] could not prepare openib device for use [water][[11549,1],0][btl_openib.c:880:mca_btl_openib_add_procs] could not prepare openib device for use EDIT 2: Following the instructions on the Open MPI website didn't help so far. Setting memlock to unlimited through ulimit isn't allowed without root privileges, and also editing limits.conf, or adding a file to limits.d, didn't have any effect (at least, not without restarting, and restarting is a no-go here) Last edited by sita; May 2, 2019 at 10:19. Reason: Additional info |
May 9, 2019, 06:46 |
Sita Drost
Rep Power: 18 |
Never mind, found a workaround: I installed the ThirdParty OpenMPI, which OpenFOAM is using now, instead of the SYSTEMOPENMPI
Still, if anyone knows how to fix these warning messages I'd love to hear about it. |
mpirun, best parameters | pablodecastillo | Hardware | 18 | November 10, 2016 13:36 |
[OpenFOAM.org] MPI compiling and version mismatch | pki | OpenFOAM Installation | 7 | June 15, 2015 17:21 |
MPI error | florencenawei | OpenFOAM Installation | 3 | October 10, 2011 02:21 |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 11:54 |
Is Testsuite on the way or not | lakeat | OpenFOAM Installation | 6 | April 28, 2008 12:12 |
