All output values increase rapidly after one cycle
Old   April 23, 2019, 21:03
Default All output values increase rapidly after one cycle
Rohan
12ohan is on a distinguished road
I'm currently doing a project using pimpleFoam which consists of two inlets and one outlet. The two inlets had been assigned almost sinusoidal flow rates with a period of 1 that range from 0 to 5 seconds. My problem is that my output values like the velocities, pressure, courant number, etc. all rapidly increase to huge values (over 1e+40) after the first second. I'm not sure why this is the case. I have tried using small deltaT values like 0.0001 and even used adjustTimeStep which made deltaT very small but the courant number increased even quicker and simulation stop at around 3.5 seconds. Below are my current files that I modified.
My p file:
Wall
type zeroGradient;
Inlet1
type zeroGradient;
Inlet2
type zeroGradient;
Outlet
type fixedValue;
value uniform 0;
My U file:
Wall
type noSlip;
Inlet1
type flowRateInletVelocity;
volumetricFlowRate tableFile;
volumetricFlowRateCoeffs
outOfBounds repeat;
file "Inlet1.csv";
extrapolateProfile false;
value uniform (0 0 0);
Inlet2
outOfBounds repeat;
file "Inlet2.csv";
Outlet
type zeroGradient;
My controlDict file:
application pimpleFoam;
startFrom startTime;
stopAt endTime;
startTime 0;
endTime 5;
deltaT 0.005;
writeControl adjustableRunTime;
writeInterval 0.02;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
adjustTimeStep no;
maxCo 1.0;
maxDeltaT 0.1;
functions
fieldAverage1
type fieldAverage;
libs ("libfieldFunctionObjects.so");
executeControl timeStep;
writeControl writeTime;
timeStart 0;
timeEnd 5;
fields
U
mean on;
prime2Mean on;
base time;
p
mean on;
prime2Mean on;
base time;
functions
forces
type forces;
libs ("libforces.so");
writeControl timeStep;
timeInterval 0.02;
log yes;
patches ("Wall");
rho rhoInf;
log true;
rhoInf 1;
CofR (0 0 0);
pitchAxis (0 0 0);
p p;
U U;
My fvSchemes file:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss LUST grad(U);
div(phi,k) Gauss limitedLinear 1;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
My fvSolution file:
solvers
p
solver PCG;
preconditioner FDIC;
tolerance 1e-06;
relTol 0;
//maxIter 100;
pFinal
$p;
relTol 0;
U
solver PBiCGStab;
preconditioner DILU;
tolerance 1e-05;
relTol 0;
//maxIter 100;
UFinal
$U;
relTol 0;
PIMPLE
momentumPredictor off;
nOuterCorrectors 1;
nCorrectors 2;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
relaxationFactors
equations
".*" 1;
It would be very nice if someone can help me out here.
Thanks.
12ohan is offline   Reply With Quote
Old   April 26, 2019, 11:52
Rohan
Hi, if someone can help me. I am new to this field and still really struggling.
Thanks.
Instabilities with too low yplus values? BendikS OpenFOAM Running, Solving & CFD 0 February 27, 2017 06:37
SIMPLE algorithm does not converge when using old pressure (correction) values andreasp Main CFD Forum 3 February 9, 2016 22:18
Nondimensional output from SU2 kmandar SU2 2 September 16, 2015 12:24
How to increase the output precision for a variable? ripperjack OpenFOAM 4 April 19, 2013 19:04
Increasing the accuracy of pressure head values in output data Saeed1390 FLUENT 0 June 13, 2011 03:17
