April 20, 2019, 14:16 |
Can I use PISOFOAM to obtain steady flows?
jawahar sivabharathy
Rep Power: 15 |
I'm using pisofoam to compute flow past a square cylinder at Re = 25.
The flow is steady at this Reynolds number, and I want to use piso for my steady state problem. My controlDict file is below ///////////////////////////////////// application pisoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 2000; deltaT 1; writeControl timeStep; writeInterval 500; purgeWrite 0; writeFormat ascii; writePrecision 12; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; ////////////////////////////////// This is my fvSchemes file ///////////////////////////////// ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss limitedLinearV 1; div(phi,k) Gauss limitedLinear 1; div(phi,epsilon) Gauss limitedLinear 1; div(phi,omega) Gauss limitedLinear 1; div(phi,R) Gauss limitedLinear 1; div(R) Gauss linear; div(phi,nuTilda) Gauss limitedLinear 1; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } The solver stops after the first iteration. The maximum courant number is around 133. Can I use piso to obtain steady-state solution? If so what changes do I need to make to obtain it? Thanks, Jawahar. |
April 23, 2019, 04:54 |
Robert
Rep Power: 12 |
Your Courant number is to high (plenty of threads about that topic). For a first step, decrease your timestep.
If you liked my answer to your question, please consider leaving a "Like" in return |
Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam | mchurchf | OpenFOAM | 7 | August 6, 2023 10:12 |
Error while running pisoFoam with snappy but ran smoothly without snappy in empty dm | faiazk | OpenFOAM Running, Solving & CFD | 0 | October 24, 2018 14:51 |
How can I get stedaystate solution from pisoFoam? | mykkujinu2201 | OpenFOAM Running, Solving & CFD | 1 | December 8, 2015 08:37 |
pisoFoam, pimpleFoam - Fluent user's questions | RodriguezFatz | OpenFOAM Running, Solving & CFD | 0 | September 4, 2013 05:26 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 18:18 |
