Problem in setting up no slip boundary condition |
April 20, 2019, 06:53 |
Rep Power: 7 |
I am solving flow through pipe. I have three patches of wall as WALL1,WALL2,HEATED WALL.
I am giving no slip boundary condition in U file, but at time of decomposePar command it shows below error Cannot find 'value' entry on patch WALL1 of field U in file "/home/vortex/OpenFOAM/vortex-3.0.1/run/PIPE/Trial1/0/U" which is required to set the values of the generic patch field. (Actual type noSlip) |
April 22, 2019, 10:31 |
Hasan Celik
Rep Power: 10 |
I assume you use OpenFOAM 3.0.1 from your post. In OpenFOAM 3.0.1, you need to define the no-slip BC by fixedValue and type uniform (0 0 0).
April 23, 2019, 11:27 |
Zander Meiring
Rep Power: 8 |
To add to PositronCascade, your pressure would also have to be set to zeroGradient on a wall
Boundary condition slip | PLanger90 | OpenFOAM Running, Solving & CFD | 6 | February 19, 2015 06:15 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Pressure Boundary Condition Problem | rbjet | CFX | 3 | July 15, 2013 21:45 |
problem with boundary condition??? | smn | CFX | 5 | November 24, 2009 06:37 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
