Power dependent heat source using fvOptions
Old   April 15, 2019, 09:45
Default Power dependent heat source using fvOptions
Raza Javed
Raza Javed is on a distinguished road
Hello Everyone,
I generated a heat source using fvOptions. but I have a confusion in this. Below attached is my fvOptions file:
heatSource
    type            scalarSemiImplicitSource;
    active          true;
    scalarSemiImplicitSourceCoeffs
        selectionMode   all; // all, cellSet, cellZone, points
       // cellZone        heatSrc;
        cellSet         c1;
        volumeMode      specific; // specific;
        injectionRateSuSp
            h     (100 0);
If I change the value of h, the value of temperature in my geometry changes, but some different value, for example, if change the value of h from 100 to 1000, the temperature changes from 304K to 340K.
what is 'h' in this file that we are changing? Is it Power? Enthalpy? or something else?
And according to which equation, the values of temperature are changing?
And my log file is given below:
 Adding fvOptions
Creating finite volume options from "constant/fvOptions"
Selecting finite volume options model type scalarSemiImplicitSource
    Source: heatSource
    - selecting all cells
    - selected 767 cell(s) with volume 1
What is volume 1 in this? because I was expecting that the value of 'h' here. but I don't understand what's happening here.
I want a heat source, in which I can change the power and get the temperature changing as a result.
Any help would be highly appreciated.
Thank you
Raza Javed is offline   Reply With Quote
fvoption, openfoam, power, temperature
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
Transient spacial dependent heat source Kumudu OpenFOAM Running, Solving & CFD 0 October 28, 2013 12:02
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
