April 13, 2019, 18:14 |
Re: adjust time step failed
Charles
Rep Power: 10 |
I'm running a simulation using interDyMFoam. In the controlDict, I set adjustTimeStep to yes, max Co to 1 etc. But the computation diverges quickly after starting when I set maxDeltaT to 0.001. Before it crashed, I saw the timestep decreasing down to 10^-8. But the change in timestep seems too late. I can manually make the computation complete. I first run the computation by setting the timestep to 0.0001, lettig it run for 1 second, stopping the run and continuing with time step changed back to 0.001s. It works. It seems that adjust time step failed but needs to change time step manually. Is there better solution? Thanks, Charles |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
