chtMultiRegionSimpleFoam Compilation Error
Old   April 9, 2019, 12:27
Default chtMultiRegionSimpleFoam Compilation Error
Raza Javed
Raza Javed is on a distinguished road
I am trying to run chtMultiRegionSimpleFoam for my problem. I have created it's geometry and mesh in Salome. After that, I imported the UNV file in OpenFoam4 and Meshed it using IdeasUnvToFoam utility. It was successfully completed without errors.
My geometry consists of three solid regions. Hot_box, cold_box, and Rod.
both these boxes are connected using the Rod between them. And I am trying to simulate the heat transfer from the Hot_box to cold_box. The figure of the mesh and geometry is attached.
After modifying the case directories according to my problem, When I run the Allrun command it gives the following error.
Solving for solid region Hot_box
--> FOAM FATAL ERROR:
cannot be called for a calculatedFvPatchField
    on patch room of field h in file "/home/openfoam/run/heatTest/0/Hot_box/h"
    You are probably trying to solve for a field with a default boundary condition.
    From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientInternalCoeffs() const [with Type = double]
    in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187.
FOAM aborting
I am unable to understand the error. Can someone help me out in this?
Thank you
Raza Javed is offline   Reply With Quote
Old   April 9, 2019, 22:31
Peter Baskovich
pete20r2 is on a distinguished road
Post the rest of your case, 0, system and constant. Mesh should be small enough to post.
pete20r2 is offline   Reply With Quote
Old   April 10, 2019, 03:50
Raza Javed
Thank you so much for your reply.
I had some mistake in writing the dictionary file for one of my regions in system folder. After rectifying it, the simulation is now running.
Now i am doing post-processing in paraview.
Thank you
boundaries condition, chtmultiregionsimplefoam, solver compilation error
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 07:45
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
