--> FOAM FATAL ERROR: Maximum number of iterations exceeded |
Kamgaing Rouxel
Rep Power: 7 ![]() |
does someone know how to solve this type of error? --> FOAM FATAL ERROR: Maximum number of iterations exceeded From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam: ![]() ![]() in file /opt/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66. FOAM aborting #0 Foam::error: ![]() #1 Foam::error::abort() at ??:? #2 Foam::heRhoThermo<Foam::rhoThermo, Foam: ![]() ![]() #3 Foam::heRhoThermo<Foam::rhoThermo, Foam: ![]() ![]() #4 ? at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 ? at ??:? Aborted Thanks a lot, Rouxel. |
Andrew
Rep Power: 8 ![]() |
i think you could solve that problem just increasing the number of maximum iteration in fvSolution, the default value is 1000 iterations.
Just change the maximum number of iterations in fvSolution, wrote for example at the bottom maxIter 5000: For ex, in fvsolution you have: k { solver preconditioner tolerance etc etc at the end you write: maxIter 5000; } |
Kamgaing Rouxel
Hi Astan,
I've tried to solve the problem using the method you show me but nothing. Its gets me out the same error. And I've noticed another error during the heat transfert, the air's temperature is too high while the CO2's temperature is going down under the absolute zero. Time = 136 Solving for fluid region air DILUPBiCG: Solving for Ux, Initial residual = 0.002098765, Final residual = 6.930776e-06, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.002774326, Final residual = 1.104634e-05, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.00120054, Final residual = 1.327856e-05, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 0.002047173, Final residual = 0.0001522865, No Iterations 1 Min/max T:308.15 948.6779 GAMG: Solving for p_rgh, Initial residual = 0.003518778, Final residual = 0.0003325344, No Iterations 4 time step continuity errors : sum local = 0.0008735108, global = -0.0001081343, cumulative = -0.04066168 Min/max rho:0.3776146 1.145686 DILUPBiCG: Solving for omega, Initial residual = 5.100526e-05, Final residual = 2.376734e-06, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.001913631, Final residual = 8.322551e-05, No Iterations 1 Solving for fluid region co2 DILUPBiCG: Solving for Ux, Initial residual = 0.003080461, Final residual = 0.0002641697, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.003234555, Final residual = 0.000315537, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.0007038237, Final residual = 6.976397e-06, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 0.002124608, Final residual = 0.000104272, No Iterations 1 --> FOAM FATAL ERROR: Maximum number of iterations exceeded |
Andrew
Kamgaing Rouxel
Hi Astan,
yeah i read it at all. And even during my research i found out that it migh be a mesh's problem. but i did the checkMesh before starting everthing and it was a pretty god mesh. i had the max non orthogonality aroud 17. |
Andrew
what's about the max skew and B.C?
Anyway, A thing that you could try is to use the smoothSolver solver insteat of PBiCG and GaussSeidel as smoother. Or you could use PBiCGStab as solver (instead of PBiCG) with DILU as preconditioner (as you are already using). if your case is about steady RANS, what's about the relaxation factor that you are using? Try to use low relaxation factors at first (for example 0.3) and once the computation goes on, you change for example 0.5 and so on). A lower relaxation factor stabilizes the computation but the convergence speed is lower, you i suggest you to do a certain number of computation (just to stabilize) and then increase. Try these settings. |
Kamgaing Rouxel
the max skewness of the mesh i've used was 0.5261681. And reguarding the B.C. i don't know if i can upload it to you for you to get a quick look?
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
