OpenFoam restarting simulation, stops at first Time loop |
April 3, 2019, 09:51 |
Christophk
Rep Power: 7 |
since a short time I can't restart my simulation, it would start and stop while doing the first time loop. I didn't change the mesh, nor the source-code, I only changed the controlDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 10000; deltaT 1; writeControl timeStep; writeInterval 50; purgeWrite 0; writeFormat ascii; writePrecision 8; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; } // ************************************************************************* // Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.0 Exec : simpleFoam Date : Apr 03 2019 Time : 12:28:20 Host : "linuxbsc299.rz.RWTH-Aachen.DE" PID : 32281 I/O : uncollated Case : /rwthfs/rz/cluster/home/ck442410/OpenFoamData nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 4100 SIMPLE: convergence criteria field U tolerance 0.0001 field p tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.55555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No MRF models present Creating finite volume options from "system/fvOptions" Selecting finite volume options model type rotorDisk Source: disk - selecting cells using cellZone c0 - selected 13440 cell(s) with volume 0.00024316376 Selecting trimModel fixedTrim Constructing blade profiles: - creating lookup profile sect0 - creating lookup profile sect1 - creating lookup profile sect2 - creating lookup profile sect3 - creating lookup profile sect4 - creating lookup profile sect5 - creating lookup profile sect6 - creating lookup profile sect7 - creating lookup profile sect8 - creating lookup profile sect9 - creating lookup profile sect10 - creating lookup profile sect11 - creating lookup profile sect12 - creating lookup profile sect13 - creating lookup profile sect14 - creating lookup profile sect15 - creating lookup profile sect16 - creating lookup profile sect17 - creating lookup profile sect18 - creating lookup profile sect19 Rotor gometry: - disk diameter = 0.29408774 - disk area = 0.067927203 - origin = (0 0 0) - r-axis = (0 1 0) - psi-axis = (1 -0 0) - z-axis = (0 0 -1) Starting time loop Time = 4101 |
April 3, 2019, 15:27 |
Lucky
Rep Power: 66 |
There's not rly any info here that can be debugged.
Even more weird... why is it starting at time 4100 if the startTime is 0? |
April 4, 2019, 03:20 |
Ruiyan Chen
Rep Power: 10 |
You need to describe the exact steps you took so people can really help you. First thing first, how did you stop the simulation? It could be simply because you changed the "stopAt" keyword to "writeNow" (to stop the simulation) and when you rerun you forgot to changed it back to a desired stopTime.
April 4, 2019, 08:50 |
Christophk
Rep Power: 7 |
I'm sorry, the controlDict wasn't exactly right. at startTime there is "latestTime".
The simulation ran on a cluster to timeStep 4130. There you have to reserve time on a node. I reserved less time, than the simulation needed to converge. So it stopped after reaching the runtime limit. I heard that it is a SIGFPE mistake, so some mathematical operation which was illegal. I figured the reason could be the write precission beine only 8. Can that be a possible reason? |
April 5, 2019, 11:20 |
Lucky
Rep Power: 66 |
If there is a SIGFPE error we would see it in the log. If writePrecision is the culprit then just use binary instead of ascii. But I don't see the sigfpe error...
I would try to start at an earlier time or even restart it from the original 0 time to see if you get the same problem. If an earlier time doesn't work but 0 time does work, then we should look at your fvOptions and whatever else you are doing that is not part of the basic simpleFoam. The best thing you can do is start at time 0 and use writeNow. Then try to start it again. |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 15:53 |
Simulation stops at Starting time loop | JMaverick93 | OpenFOAM Running, Solving & CFD | 3 | March 18, 2018 06:08 |
How to export time series of variables for one point? | mary mor | OpenFOAM Post-Processing | 8 | July 19, 2017 10:54 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
