BuoyantBoussinesqSimpleFoam_Facing problem
Old   April 3, 2019, 01:06
Default BuoyantBoussinesqSimpleFoam_Facing problem
Mondal131211's Avatar
Mondal
Mondal131211 is on a distinguished road
Hi Foamers,
Here is a common problem that gave me huge pain. Though it is a simple problem, I need to figure it out about this problem. I am trying to simulate natural convection inside a square enclosure. The left wall of my problem is considered as Hot while the right wall is cold. The top and bottom walls are insulated. This is a simple 2D laminar case. I am using buoyantBoussinesqSimpleFoam (OpenFOAM 3.0.1) for solving this problem. Its an incompressible solver for the steady-state problem that deals with buoyancy driven flow.
The solution goes fine but it seems to me the flow does not change if I change any parameter related to thermophysical properties (Ra number, Gr number, etc) file. I did not notice any temperature gradient close to the wall. If there is no temperature gradient along the heated wall, how the flow will change. I can not understand what the problem is, what are the mistakes did I make every time. I have attached here one of my tried case files. I have studied the same incompressible problem solved by other software gave good result even in the OpenFOAM as well. But what is wrong with my solver, cannot understand.
I have some questions,
can anyone tell me what is the reference temperature inside the thermophysical properties? Is that same as internal field temperature?
What properties should carefully be handled when solving by buoyantBoussinesqSimpleFoam?
I know this is a silly problem but snatched my couple of months. I just need to figure out what is the key factor in OpenFOAM Boussinesq approximation.
I will appreciate any suggestions regarding this problem. Please answer me in the OpenFOAM context as I know the physics of the problem.
Cheers,
Razon
Mondal131211 is offline   Reply With Quote
Old   April 10, 2019, 20:41
Default https://www.cfd-online.com/Forums/openfoam-solving/216302-buoyantboussinesqsimplefoam
Mondal
Any help for this problem?
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
