p_rgh residual diverging for chtMultiRegionFoam case with cyclic boundary conditions
Old   April 1, 2019, 23:06
Default p_rgh residual diverging for chtMultiRegionFoam case with cyclic boundary conditions
pedanticphysicspanda is on a distinguished road
Hello all,
I am attempting to get a case involving a smooth duct with a metal region on bottom to run. I am using chtMultiRegionFoam and so far get decent results if i define the boundary conditions with the standard input output pressures and velocities but run into trouble when I include cyclic boundary conditions. For some reason I am getting a divergence in p_rgh, among other errors, when I run it. I have tried many things and cannot seem to figure this one out. I can get a regular cyclic case to run fine just not with conjugate heat transfer.
I am new to this, so I am not sure what would be necessary to diagnose and am just posting the 0 directory. Any guidance is appreciated.
Thanks,
Caleb
pedanticphysicspanda is offline   Reply With Quote
Old   April 2, 2019, 01:36
Adam
Adam_K is on a distinguished road
You should post your entire case file. With only the /0 directory, we can't see how the neighbouring patches are defined, those should be in the boundary files located in /constant.
Adam_K is offline   Reply With Quote
Old   April 2, 2019, 12:41
The case file is too large for me to post. How do I get around this.Attached is the boundary file.
Thanks,
Caleb
File Type: zip boundary.zip (680 Bytes, 10 views)
chtmultiregionfoam, periodic bc
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
