Wall function values
Old   March 27, 2019, 20:25
Default Wall function values
Brett
Bdew8556 is on a distinguished road
Hi Foamers,
I've been doing research on wall functions, which ones to use, which ones might suit me etc...
I'm a bit stuck on what value I should be setting them at, for example:
Bottom_Wall
type omegaWallFunction;
value uniform 1;
But how do I get any guidance as to what the value uniform should be? why 1? why not 0.1, or 100?
Any thoughts?
Bdew8556 is offline   Reply With Quote
Old   March 28, 2019, 04:06
Robert
RobertHB is on a distinguished road
I'm either using the field values or zero. Both give comparable results.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
wall funtions openfoam
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
