Slow and unstable severe slug simulation using compressibleInterFoam |
March 26, 2019, 05:36 |
Rasmus Jørgensen
Rep Power: 7 |
Hi Foamers!
We are two graduate students currently doing our first CFD project involving multi-phase flow. Our previous CFD experience is limited to incompressible single-phase flow using ANSYS Fluent, so it is also our first use of OpenFOAM. We have simulated different tutorials and simple cases during the last months and are becoming more confident with the OpenFOAM structure. Our case is a pipeline with a fixed inlet mass flow rate of air and water and fixed pressure of 100 kPa at the outlet on a 630k cell mesh created using blockMesh. The zipped case is available from https://drive.google.com/open?id=1L7...nZnTtXXgN54waq. A single timestep is available in the processor folders for when the water has just reached the lowest point of the pipeline (which is actually 95 seconds of simulation). We have stitched together the current case setup from different tutorials, mainly angledDuct (interFoam, RAS) and and bubbleColumn (compressibleInterFoam, laminar) as they have inlet and outlet boundaries such as our case and applies compressibleInterFoam and turbulence modelling, respectively. Also, we have applied changes to the 0 and system files based on tips and tricks from the internet. However, we are struggling a bit with stability and speed. As the flow reaches the bottom of the pipeline vertical section, we have to decrease maximum Courant numbers to as low as 0.2 to continue solving. As we hope to simulate 100-200 seconds, an achievable deltaT of 0.3 msec is a bit less than we had hoped for. We have currently decomposed the case to run on 14 threads. Our hardware and software specs: - 2x Intel Xeon E5-2637 V4, 4-Core, 3.50 GHz Processor (8 cores and 16 threds in total) - 256 GB DDR4-2400 RAM - 300 GB SSD - Ubuntu 18.04 LTS - OpenFOAM v6 We suspect that our inferior knowledge might have caused us to apply inappropriate boundary coniditon, discretization schemes or solvers causing such poor performance. We hope you can provide feedback on our case - any help is greatly appreciated! With best regards, Rasmus |
March 31, 2019, 14:00 |
Geir Karlsen
Rep Power: 13 |
Greetings!
The time step in your case is adjusted based on the Courant number. As you know, the Courant number is calculated based on the local velocity, the distance between mesh elements and the time step. So, if you want the time step to be higher there is basically three things you can do: - Reduce the velocity - Coarsen the mesh (primarily in areas with high velocity). Elongating cells in the flow direction could be one option. - Increase the courant number To increase the maxAlphaCo beyond 0.2 and still maintain stability. You could increase the number of alphaSubCycles (fvSolution). E.g. to 4 with a maxAlphaCo=0.8. This will however only help if the time step is held back by the interface Courant number and not overall Courant number. Changing numerical options could reduce the solve time, but will not affect the time step. For your 8 physical cores it typically does not improve the speed to decompose the domain into more than 8 parts. In fact, many find that they get better performance by turning off hyperthreading completely in the BIOS. I highly recommend the hardware sub forum for more information on this topic. It also includes a openfoam benchmark in a sticky thread. By running the benchmark you could ensure that your hardware is running at its expected performance, and also evaluate how it scales with number of sub-domains Hopefully, someone might have suggestions for faster numerical schemes for you as well. Good luck |
April 1, 2019, 03:09 |
Rasmus Jørgensen
Rep Power: 7 |
Thanks for your reply, Geir! It is much appreciated.
We will try to modify our setup based on your feedback. Regarding hyperthreading, we have already reduced the decomposition to 7 parts, and noticed a significant performance gain. We will try to investigate the possibility of disabling hyperthreading all together. Best regards, Rasmus |
[waves2Foam] Unstable simulation when using 'stokesFirstwCurrent' | Ahmed Elhanafi | OpenFOAM Community Contributions | 1 | October 19, 2017 13:45 |
