heatTransfer solvers with high density variations
Old   March 25, 2019, 10:05
Default heatTransfer solvers with high density variations
pod
pod is on a distinguished road
Hello everybody,
I am trying to simulate a phase transition (liquid vapor) without involving in chtFoam neither eulerFoam method nor interFoam method. So basically just by accounting for the density change according to temperature. The simulation seems to be really unstable because of the density correction in the pressure calculation. So I was wondering:
- I tried to provide the solver with interpolating tables of density and calculating the compressibility just by dividing by the pressure; I also tried to provide tables of compressibility as well; but none of these options seems to work, what should it be the right way to calculate rho and psi while having a stable code?
- is it even possible to run a simulation in chtMultiRegionFoam with such big density jumps without implementing additional parts like in multiphase solvers? Could it be an option to change the pressure algorithm of this solver to the psi-based one of compressible solvers like rhoPimpleFoam to make it stable and absorb the density correction term?
thank you for any advice,
cheers
pod is offline   Reply With Quote
chtmulitregionfoam, liquid gas, phase change
Incompressible and compressible flow. Confused student. Main CFD Forum 27 March 18, 2017 13:25
Problem on high density ratio in Level Set method Kai Yan Main CFD Forum 10 December 25, 2007 07:12
pressure and density based solvers sun Main CFD Forum 0 November 8, 2004 07:20
Pressure vs Density based CFD solvers Danie Main CFD Forum 0 October 5, 2004 10:48
variable density water Atit Koonsrisuk CFX 2 July 24, 2003 04:07
